Old 06-20-2021, 09:02 PM   #22
ls1nova71
ls1nova71's Avatar
Re: First time swap started
Originally Posted by TrybalRage View Post
For reference, I used this image (courtesy of Scotty Baccus from from the LS Swapped Square body facebook group) for my wiring of the AC system (already had the fans wired previously).
This will work for the fans and will control the A/C compressor, will cut it off at full throttle too, but it doesn't appear there is any A/C control over the fans in this schematic. As long as the engine is up to temperature and the fans are already on it will work alright, but until then you will have no fans pulling air across the condenser. Also, you will almost never have the high speed fans on, which will make the A/C temperature in the cab warmer than you will probably like when you're not moving above 40mph or so. Just something to think about. I would put a trinary switch in it to control the fans whenever the A/C needs them.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
