But Found Her 25yrs Later!
60-62 Frame Horns
Common problem with them cracking and breaking.
I had hoped to replace them with the 63-66 style, but it's not just about the bolt spacing, the 60-62 bumper contour is different than the 63-66. I know I could find someone who has a nicer set they could cut off an old frame, but I'd like to see if we could come up with another solution. Has anyone fabricated their own new horns?
Re: 60-62 Frame Horns
I actually made it this far before I realized the shape of the bumpers are different. I knew the bolt spacing was different, but I didn't realize the shape of the bumpers on 63-66 were different from the 60-62.
![]() Join Date: Aug 2010
You've gone that far, why not just find a 63-66 bumper to fit the new horns? Or am I missing something?
They're not welded yet. Just hanging there for mock up.
Yes, I've considered getting a 63-66 Chrome Bumper. I've got one more thing I'm going to try. I would rather not spend $180.
![]() ![]() Join Date: Apr 2012
Isn't the 63-66 frame taller here ? Might interfere with the grille surround . The notches in the surround for 63-66 are taller or deeper than 60-62.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
yes, my grill support happens to be from a 65. my 65 is on a 62 frame.
I'll chalk it up to another lesson learned.
No big deal. I went ahead and repaired the 62 horns. I'm comfortable with my welding skills. I'll just weld them back on. ![]()
Active Member
![]() Join Date: Nov 2011
My front frame horns are shot too so if anyone has '60-'62 horns or another solution, please reply.
I cut mine off. Bolted the broken pieces to the bumper. Tack welded the pieces together. Then welded the repaired horns back on.
I would weld in some gussets to keep it from happening again.
Saving ron's post for future reference:
I am in the same predicament. I currently have a set of frame horns from a 63-66. If I welded those on to my 60 Chevy would I just have to use the 63 to 66 bumper?
Yes
Yes, I just want to do few more alignment checks before I reinforce them.
#15 |
It's almost like there should be a reinforcement piece that could be fabricated to bolt to the existing frame. That way even those without the ability to weld could just bolt it up.
