Old 07-14-2004, 08:33 PM   #26
miket
miket's Avatar
Originally Posted by BobbyK
Mike I just read that link.I'm not aware of an internal resistor.
Soldering a resistor in the "L" line is easy and proven to work.
Yup me either---and I just rebuilt the one I am trying to install and I didn't see anything of the kind...
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 07-14-2004, 08:42 PM   #27
miket
miket's Avatar
Not to beat a dead horse here, but I looked at how my CS144 is wired in my 94 Caprice...it has a single 4 gauge running over to the battery and only two, maybe 18 gauge, wires coming out of the plug....now I know this car has a PCM but how does the alt sense the load and adjust accordingly? There are only two brown wires and one is for an light and the other is voltage sense. There isn't even a jumper from the charge termical over to the plug...wierd. This is roughly the same car my truck alt came out of.
Old 07-15-2004, 10:16 AM   #28
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Sorry Mike,I don't know how GM wired up the Caprice.
I'd need a schematic to figure it out.
Almost sounds like a one wire set-up,in the way the charge wire goes directly to the battery.
I can't see GM useing a 1 wire set-up though.
I'm sure there is a load signal getting to the ECM somehow.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 07-15-2004, 10:57 AM   #29
miket
miket's Avatar
Yes I think so.....thanks.
Old 07-15-2004, 05:03 PM   #30
miket
miket's Avatar
Finished
Well it's finished. Drove it a while ago...phase 1 is done...phase 2 will be the power wire upgrade and distribution block.
Old 07-15-2004, 07:16 PM   #31
BobbyK
BobbyK's Avatar
Glad it works.
Good job!
Old 07-15-2004, 07:49 PM   #32
miket
miket's Avatar
Glad it works.
Good job!
Hey thanks for your help!!!
