![]() Join Date: May 2007
Re: 51 Chev on a S10 frame, named Dale
thats a looker for sure, sorry about your covid problems
Had a problem with the truck, at 40 mph, under load, the engine would sputter, cough, and chug. This only happened under load, if I depress the clutch and rev it, no problems.
Hmmmmm, is this a fuel problem? or an electrical problem? So, added some 93 octane fuel, no change, then I replaced the fuel filter, no change. Maybe it is an electrical problem?? I used a brand new distributor, so it should not be that?? but what else?? maybe the coil (HEI) was breaking down? So, I had an old distributor, and changed caps, still no change. OK, maybe it is the module in the distributor??? so I went back to my used distributor, removed the module, (added some dielectric grease to the bottom) put it in the truck and ...... FIXED ! no more problems, cruising along past 40 mph without a hiccup. I purchased a new complete distributor the the very reason of not having these problems, but they still occur. All is well, and noticed I have just put 500 miles on it so far this summer. Hope you are all enjoying your trucks this summer.
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
![]() Join Date: Sep 2017
Nice work on the find and fix.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
KISS , Keep It Simple Stupid... that is my motto, and this is a perfect example why I like Carburetors and Distributors.
If this was happening with a computer controlled motor, I would be lost.
computers suck....Points and condensers, rock.
http://67-72chevytrucks.com/vboard/s...82#post8619382 |
