Old 06-25-2021, 10:13 PM   #101
56 3100
56 3100's Avatar
Re: 1956 3100 build
tailgate link straps and latches fitted.gonna look clean out back.
aftermarket rear brace doesnt have license plate bracket holes.
56 3100 is offline   Reply With Quote
Old 06-26-2021, 01:23 AM   #102
joedoh
joedoh's Avatar
Re: 1956 3100 build
that does look clean!
Old 06-26-2021, 10:01 AM   #103
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 1956 3100 build
x2!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 06-26-2021, 10:35 AM   #104
62 Barnfind
62 Barnfind's Avatar
Re: 1956 3100 build
Originally Posted by 56 3100 View Post
hey barnfind good to have another set of eyes to look at the pics.body guys tough part next is gonna be hood to front fender gaps.i sent him some pics and videos showing slicing front fenders to close gap.if all goes well might get truck back from paint shop for summer.
I did mine that way. I got it real close to looking right.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 06-29-2021, 09:05 PM   #105
56 3100
56 3100's Avatar
Re: 1956 3100 build
filled in notches where chain tabs go.
Old 06-30-2021, 09:18 AM   #106
my56chevytruck
my56chevytruck's Avatar
Re: 1956 3100 build
good job on the tailgate latching. Looks clean and slick
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 10-13-2021, 08:52 PM   #107
56 3100
56 3100's Avatar
Re: 1956 3100 build
getting closer on lower dash valence being finished . using round container wrapped in sand paper to get in corners.
started getting dash cover ready to go with lower dash.
[url=https://ibb.co/PWVwfVG][/url
put rear fender on to check stance and see how rounded box rails and chains being shaved look.
Old 10-13-2021, 09:09 PM   #108
dsraven
Re: 1956 3100 build
Looks great.
I bought an el cheapo deluxe rubber drum sanding kurt from princess auto it works great for those round corners.
Old 10-15-2021, 09:24 PM   #109
56 3100
56 3100's Avatar
Re: 1956 3100 build
cut out dash today point of no return. brothers youtube video was a big help.
Old 10-16-2021, 02:52 PM   #110
NorCalGal
NorCalGal's Avatar
Re: 1956 3100 build
You’re doing some beautiful work.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 10-16-2021, 02:56 PM   #111
dsraven
Re: 1956 3100 build
Looks like you have some patience testing coming right up. Tack wait, tack wait. Should be awesome when done though.
Old 10-16-2021, 10:27 PM   #112
56 3100
56 3100's Avatar
Re: 1956 3100 build
thanks norcal . found most of the ideas in this forum. hey raven will hopefully start tacking panel in tomorrow wil post pic. was kinda nervous when i started the mini grinder to cut out old dash.
Old 10-17-2021, 12:17 AM   #113
dsraven
Re: 1956 3100 build
haha, yeah, I know. been there on a few different things. should i do this differently? is there a better way? let me research this first. then. when all said and done, you tape off a line and grab a zip disc. took less time to do than it did to research. lol.
I use autobody tape a lot for stuff like making a line for zip disc cutting. it sticks pretty well and makes a good line to cut against. for the zip discs, actually I have switched to mostly the lennox metalmax disc. it is a steel blade with diamond embedded on the cutting surface so it doesn't get smaller as you cut and it doesn't periodically explode and leave shards under your skin for future reference. I usually cut the hole a little on the small side and then use my die grinder to custom fit a nice tight space for welding the new part in. panel clamps would work awesome on your project. clecos work well too. what I have done in the past is make a tight fitting panel, then where the clecos will go I simply make a little hole in the crack between the parts so the cleco will fit in. sometimes you need a small washer on the back side if it is accessible. then, as I'm sure you are well accustomed to, it is tack, tack, tack around the 4 sides till it's all stuck. then tack between those tacks and then more between those tacks until it is fully welded in. yup, time consuming to do it right so it doesn't warp. you been there. looking good too.
Old 10-18-2021, 06:52 PM   #114
56 3100
56 3100's Avatar
Re: 1956 3100 build
hey dsraven, i picked up some of those panel clamps during one of our last cross border shopping to bangor, maine a few years ago.they had them at harbour freight(USA version of princess auto) i miss the cross border shopping.
i achieved a good gap for welding took a break there. will start tacking into place tomorrwow. i used glove box door as a template . i had a local shop bend cost was like $50.00.
Old 10-18-2021, 08:07 PM   #115
dsraven
Re: 1956 3100 build
nice thinking on the home spun parts. I like it. are you using panel adhesive or spot welding or a combination?
Old 10-18-2021, 09:32 PM   #116
56 3100
56 3100's Avatar
Re: 1956 3100 build
welding a few spots at a time .
Old 10-21-2021, 07:19 PM   #117
56 3100
56 3100's Avatar
Re: 1956 3100 build
lots of tack welds .but got panel nice and even. panel clamps work as intended.
Old 01-14-2022, 12:45 AM   #118
56 3100
56 3100's Avatar
Re: 1956 3100 build
a little update vintage air vents and controller holes cut out . my body guy started on dash so cab finished soon yeahhh.
i am trying to get as much done on frame related stuff as i can before i need to send to body shop for cab to mount.hydroboost hoses clamped in place.
mercedes electric fan fabbed up .made new wider mounting brackets for rad so i had room to locate for fan.
fuel line routed and clamped along with battery cables.
Old 01-14-2022, 12:50 AM   #119
JML55
JML55's Avatar
Re: 1956 3100 build
Looking good my friend
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 01-14-2022, 03:04 PM   #120
bowt1ed
Re: 1956 3100 build
thanks jean-marc. we have you cold weather here now! i have been gathering parts for truck since i bought it in 1995 i figured it was time to start the build. it was fun to drive stock for a couple years with the pitina look?(right spelling). you could see massy ferguson on bottom of door faded in. some plumbing company name could be seen in another spot. what was funny is someone using drivers side inner roof for records. it had the amount of wolves and grass hoppers someone might have saw/counted plus acouple of oil change dates written in as well. i am waiting on a pair of rear fender tubs that would finish out the bed of truck . flange on tubs match bed stips when using wood bed.
Like the 2 narrow indentations on those wheel tubs, as they match the TF bed sides. Unfortunately, can't find any aftermarket ones for a 66- Suburban. Jim
bowt1ed is offline   Reply With Quote
Old 01-14-2022, 07:58 PM   #121
56 3100
56 3100's Avatar
Re: 1956 3100 build
hey Jean Marc thanks .been a long time coming but hopefully on the road this summer. the rear tubs do blend in good with box sides bowt1ed
Old 03-18-2022, 10:49 PM   #122
56 3100
56 3100's Avatar
Re: 1956 3100 build
got some surprise pics from body shop.pretty exciting!
Old 03-19-2022, 08:41 AM   #123
Denee007
Denee007's Avatar
Re: 1956 3100 build
OMG~~ That is beautiful~!! I love the color!! I bet you're excited!!!
dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 03-19-2022, 10:15 AM   #124
57FleetsideC4
Re: 1956 3100 build
Great color!! Like to see it done. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 03-19-2022, 09:17 PM   #125
56 3100
56 3100's Avatar
Re: 1956 3100 build
Pretty exciting to see some paint finally for sure.
