Old 06-27-2021, 08:06 AM   #26
Zippi
Zippi's Avatar
Re: Glove box not closing correctly
When I installed mine I not only had to adjust the tab to get it to shut as best it would I also had to play around with the (4) screws (two on each side) to get the gaps right. Best I can remember they all come into play. I had to keep making adjustments until I got it the way I wanted.
If you can't fix it with duct tape, it's an electrical problem.
1949 5 Window 3100
https://zippi6.wixsite.com/adtruck
Zippi is offline   Reply With Quote
Old 06-28-2021, 11:39 AM   #27
Greyhound101
Yes, I had to do the same thing. Once I got the tab to fit as best as I could, I played around with the hinge screws to get it to shut better. It's not perfect, but you have to look really close to see it's not perfect.
Greyhound101 is offline   Reply With Quote
