Fabricate till you "puke"
20 to 10 series top arms?
Its been a while, but the old crazy man is playing with the longhorn again! The camber will not come on right, due to the 3/4 ton top arms....am looking @ Ride tech top arms (1/2 ton). I understand, that the 10-30 series cross members are pretty much the same, but have to ask about the studs, that mount the top cross shaft for the A-arm? To give a little info, she has 71 lower arms, 75 spindles/ball joints /69/3/4 ton top arms & shafts. My big ?, is will the top studs accept the 1/2 ton cross shaft, or do I need to replace the top studs or mounts? Need help......Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: 20 to 10 series top arms?
Never mind guys.....I have it figured
Upper a-arms are the same length between C20 & C10. No camber gain to be had just going to the C10 part. RideTechs stuff is adjustable for offset (Camber) & uses different 'slugs' for Caster.
Moog makes/made an offset upper shaft (k6184) for the stock 73-87 year arms.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-26-2021 at 06:02 PM. |
Thanks for the reply Scoti....I had hoped that you & Capt fab would ,chime in
#5 | |
Target a minimum of NEG .5 Camber. There won't be any difference in tire wear @ that setting but corner grip will be better. Do the Caster mod w/the lower arms as well. it's easy to get 5-6° POS Caster.
The upper a arms are the same but in my experience the 3/4 ton upper shaft is thicker pushing the top of the wheel out giving you the positive camber.
You could.possibly machine the upper control arm shaft thinner at the mounting points.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Thanks again to all .....I had thought about moving the lower arm forward. I have a drill press, & can do that mod
#8 | |
Just installed these with my 70 cross member. Problem is earlier trucks used a round concave washer behind the control arm shaft that matches the convex area around the studs for caster adjustment. 73 and up use a washer that is flat on the back side and curved on the control arm side to match the control arm. If you install both washers you have too much positive camber without any shims.
#10 | |
I'll look @ my stuff & see if I can jog the memory (I think it was on my dually).
#11 | |
#12 | ||
I like the drop/stance....2 1/2 on the spring, + 1 1/2 on the body drop.The way the old truck is set up, nothing drags the pavement!. The rear is a flip/relocate brackets, for about a 5 inch drop. With the 4 inch chop top, the top it is about shoulder height on this 5ft 9 old man @ the top.....I do not want lower, just want to bring it (square) with what I have. Longhorn
I purchased a caster camber guage, & was able to pull the camber in to 1 degree positive, & the caster to 2 1/2 degrees positive.....should be within factory spec? It will take machine work to get to the custom/performance specs, but that will be over the winter. Thanks to all for replies, Longhorn
#15 | |
#16 |
I do understand that Scotty....it should be about 1/2 degree negative , on the camber.....but will take machine work on the top shafts to get there. In my understanding, I am within factory specs? Let it run for the season....take it down over the winter & then play with caster/camber
#17 | |
I recall the OE target was +0 to +1 camber. This is why I target the .5 NEG as my minimum. Given your limitation, it makes sense to align as best you can w/what you have.
#18 |
Thanks again.....with a little help from a good bunch of brother truckers, she will rock
#19 |
What series suspension are you running (10 or 20)?
#20 |
I am running 10 series suspension.....she does have the 20 series top arms/shafts, & a pair of 71 (10 series) lower arms. The rest is 75 10 series, on the spindles, ball joints & outer tie rod ends. The springs are 10 series, with 1 ring off the bottom. I also fabbed shock relocators, trimmed the bump stops & left the steer stop on the lower arms. She also has a 30 series sway bar, with fabbed brackets to fit .IIRC , the bar was flipped upside down to fit. Thanks again.....longhorn
#21 | |
#22 |
Good idea Scoti......I will check that route out. I guess it is a matter of , the cost of parts vs the machine work? All the parts on my truck are fresh(within 6000 miles). Let us go
#23 | |
Having limited access to early C20's/30's (pre-73), I have been told they utilized 9/16" upper mounting studs but never had one to validate the info personally. Most later disc brake 1/2 tons utilize 1/2" upper studs. HD trucks were 9/16". Early pre-disc brake lower control arm U-bolts were 1/2". Post-72 disc brake are 9/16". I just put calipers on the old/original upper shafts from my 64 as well as a pair of uppers I got from one of N2billets 67-70 builds. These are original shafts & they allow a 9/16" bolt to pass through. The old/original x-member from my 64 has 1/2" upper mounting studs. The post-72 pancaked x-member I have has 1/2" upper mounting studs. The early shaft diameters are 15/16" & flat where the bolts pass through (no Concave shape). The later shaft I have is 7/8" @ the shaft & ~1" where the stud passes through (w/the Concave notch). Point of all this is it's quite probable the C10 shafts fit what you have w/o drilling anything. I would check the dimensions for what you have & compare. There might be no gain or @ the minimum a possible 1/8" gain if one side is flat.
