Old 07-16-2004, 12:11 AM   #1
JQ-72
JQ-72's Avatar
front springs question - experts help!!
I recently got my first 4wd truck so I'm having learning alot about them. My front springs have a slight downward arch to them. Is that normal? I thought they were supposed to have an upward arch or at least be level. The truck is a 72 3/4 ton. Are there supposed to be 3 tapered leafs? Also, if I need new springs, will ones off 73-87 fit? Thanks for any help.
Joshua
JQ-72 is offline   Reply With Quote
Old 07-16-2004, 12:13 AM   #2
JQ-72
JQ-72's Avatar
another:
Old 07-16-2004, 12:31 AM   #3
Mudder
Mudder's Avatar
The 73 and new trucks do have a arch like that but someone has added lift in the front using cut springs. I would get those off of there soon and get some new springs. I do believe they have messed with the spring pack. They don't look right to me.
Mudder is offline   Reply With Quote
Old 07-16-2004, 05:43 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Back then the manufactures weren't as concerned about ride height. They all have a slight backwards arch. It actually is suppose to ride smoother. In your second pic it lookss like you have a bent spring(top one). And like mudder said, it looks like a leaf was added. both my trucks had the heavy duty front spring option from the factory which is basically 3 leaves v. 2 leaves and they did not look like that. 73 and up springs will not work as they are 3" too long. Also looks like somebody cut a bunch of springs(4) to stack up front to get more height. Your truck probably sits about 1.5" higher than stock.
My opinion- If you wanted it to stay where it is height wise get some 2" lift front springs.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-16-2004, 04:11 PM   #5
kickinasphalt
kickinasphalt's Avatar
I have some 2" Skyjacker front/rear springs that I just pulled off my 72 K10.
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73
1972 C-10 Longbox,350/350
1998 Pontiac Grand Prix GTP
FOR SALE: 1971 K-10 Longbox,350/SM465/NP205
kickinasphalt is offline   Reply With Quote
Old 07-16-2004, 11:45 PM   #6
stan79chevy
stan79chevy's Avatar
that dont look safe
i know blocks up front is a no no im sure slabs of old springs is too. my 79 has the reverse arch thing too. i think they start out level and then start sagging down over time.
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 07-17-2004, 07:23 AM   #7
Destructo
you do have a bent spring on the passenger side looks like, I would put some different springs in there, but don't worry about the negative arch thats pretty normal, and i'm not sure but it looked like there was a shorter leaf between two longer leafs, don't know if thats normal or not, and those cut leafs under the springs are no good, I would remove those.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
