Window regulator installation ??
So I’m getting ready to install the door internals, have read all of the threads and watched videos and have an unanswered question.
The top two rollers on the regulator go in the window sash. Where does the lone bottom roller go? I don’t see anything on the door that would suggest that there is a lower channel that it rides in. Thanks in advance. |
![]() ![]() Join Date: Jan 2005
Re: Window regulator installation ??
There is a small track attached to the back of the inner wall of the door where that lone roller rides. You can see it if you roll your window down all the way and shine a flashlight down into the window opening.
This track is above the big opening on the inside of the door. Depending on where the "crank" is positioned that lone roller could be above or below the other two if that makes sense.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
![]() Join Date: Sep 2014
So I have an original door and intervals for both left and right doors. I done have the track that the lower roller rides in. Does anyone know if they are reproduced and what they are called? Thanks!
Never mind! I just found it. Thanks again
