Old 06-27-2021, 03:15 AM   #2226
BRL
BRL's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by cab4word67 View Post
That is so cool!
Have you done a post on that tilt front end yet?
Pop the hood, climb over the radiator and be all crunched up working on your engine...naw, just tilt the works and stand beside the engine.
I think this old guy would appreciate that.
You could even use the front wheel as a chair.
BRL is offline   Reply With Quote
Old 06-27-2021, 10:55 AM   #2227
davischevy
davischevy's Avatar
After recalibrating the POA, I charged the AC on Mean Green with 134A.
I took momma for a test drive and everybody is happy.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 06-27-2021, 11:00 AM   #2228
Davidf
Finished all under hood wiring on the LS swap. Attention now turned to getting a/c connected with ls compressor, and switch to accumulator/orifice tube/r134a.
Davidf is offline   Reply With Quote
Old 06-27-2021, 01:30 PM   #2229
body bolt
Replaced the fuel pump and installed a phenolic insulator along with it.
body bolt is offline   Reply With Quote
Old 06-28-2021, 10:26 PM   #2230
cab4word67
cab4word67's Avatar
58 days, almost done bringing her down to the weeds, Sure looks good. Still need to adjust the hood some.
cab4word67 is offline   Reply With Quote
Old 06-28-2021, 10:35 PM   #2231
cab4word67
cab4word67's Avatar
Originally Posted by BRL View Post
That is so cool!
I used the 17x40s as chairs abd now i can sit on these little one just the same.
The tilt, had it for 40 years just to find the engine with the lift. Now I can trip over it. The door handles will be next. You can see my 70s 3 turn TA steering box in this picture. I did that before "IDIDIT" was even a name. linked it to a 70s Eldorado telescopic tilt and added a corvette wheel, all in the late 70s. Even the power brakes is out of a 76 K20. Back then we made stuff work.
Old 06-29-2021, 10:10 AM   #2232
body bolt
Put a Mr. Gasket insulator between the manifold and Quadrajet. It was too cool yesterday to know if this cures the hot idle problem.
Old 06-29-2021, 09:29 PM   #2233
KQQL IT
At the body shop.
KQQL IT's Avatar
New tint and new rubber gasket.
The lower corner wasn't as nice as I'd liked.
Old 07-05-2021, 11:54 PM   #2234
allchevy58
allchevy58's Avatar
Took hood and fenders off to install front fender seals, cleaned up mess from wet sanding truck. Going to get the new windshield and back window installed while there off. Less chance of scratching cowl, hood or fenders.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 07-06-2021, 12:37 AM   #2235
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
GM sure put on fine vinyl products. 50 years, sometimes the best storage place is on the truck, though I do keep it covered.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-08-2021, 02:39 PM   #2236
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Well didn't do it today but took my virgin small block 400 and its crankshaft for machining last week. Getting annxious to get it together and in my truck. Also took valve covers and oil pan for a deep cleaning.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-08-2021, 05:46 PM   #2237
YellowK5
Active Member
Cool..I just called the machine shop so I can take my 350 in ..I pulled it out of my 72 Blazer. As soon as this one is done I will rebuild the 350 in my C20 long bed. Just need to pull the cam and lifters
YellowK5 is offline   Reply With Quote
Old 07-08-2021, 06:20 PM   #2238
CG
BlahBlahBlah
I have an NOS black dash pad in a tube somewhere, doesnt look any better than yours.
Old 07-08-2021, 06:36 PM   #2239
Smitty
Smitty's Avatar
Head up butt. Backed into post this morning. Removed head. Made appt. at body shop and ordered new bumper from Wes.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 07-08-2021, 07:00 PM   #2240
72Teeroy
Ouch man sorry to hear about that
72Teeroy is offline   Reply With Quote
Old 07-08-2021, 07:36 PM   #2241
72Teeroy
Old 07-08-2021, 09:22 PM   #2242
67C10Step
67C10Step's Avatar
Got my Boyd’s tank and accessories delivered today. Could not help myself but to do a quick fit test. Will try to mount it up this weekend.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 07-09-2021, 12:07 AM   #2243
cab4word67
cab4word67's Avatar
Drove mine today, god Im lovin this thing now that its down on the ground.
Old 07-09-2021, 08:08 PM   #2244
tim_mc
tim_mc's Avatar
Just picked up mine from Custom Differentials in Bloomsdale, MO. Jeremy's team upgraded my 12-bolt open diff 3.08 to a 3.42 posi. No more whine and now 2-wheel peel! The old pinion bearing was heading south in a hurry. I can now hear myself think while cruising down the interstate. I also needed new axles. Tomorrow I'll pull the speedo cable on the 700R4 and see what driven gear is in there since my speedo is fast by about 15%. Per the rule, add 1 tooth for every 5% difference if the speedo is faster than actual. Thanks Jeremy!
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 07-11-2021, 05:17 AM   #2245
OregonNed
OregonNed's Avatar
Mine just came back from a complete rebuild and upgrade of the differential - went from open carrier 3:08 to Eaton Posi with 3:42 gearing. I also finally received my new vent window assemblies to join my new door windows for that project. going into my 3rd month waiting for new regulators to get this done - hopefully by the end of July.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 07-11-2021, 01:09 PM   #2246
ChevyGuyNC
ChevyGuyNC's Avatar
Replaced the high beam kick switch, and adjusted the glovebox door as it wasn't opening without pulling on it.
Up next, after a couple cruise-ins will be the carb rebuild and recharge the AC. Oh and search for an old post that had a link to a twist valve for the heater hose. (Edit- found it, ordered)
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor
ChevyGuyNC is offline   Reply With Quote
Old 07-11-2021, 01:37 PM   #2247
KQQL IT
At the body shop.
KQQL IT's Avatar
Washed it in 108° that's enough for me.
Old 07-13-2021, 09:38 AM   #2248
67C10Step
67C10Step's Avatar
Not today but over the weekend I did manage to get the Boyd's tank in it's permanent home, bed box epoxy primed, assembled, and test fit back on the truck. Run new fuel lines and sending unit wire next.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 07-13-2021, 05:32 PM   #2249
ChevyGuyNC
ChevyGuyNC's Avatar
No pics but... decided to disconnect the heater core rather than use the manual shut off valve.... I looked at it and figured even if I have the valve on the engine block side, hot water could still flow from the radiator side into the core and thus into the cab. So I ran from the block to the radiator and left the heater core disconnected. Doubt I'll ever need the heat in FL even in Dec/Jan....
A/C seems to run a whole lot better now.... big test will be running down to Daytona Buccee's tomorrow for a C10 Club FL meet.
Dash lights are all working now too... LED's for illumination, 194 incandescent for the idiot lights.
After the next two events, carb will go to National Carburetors for rebuild. They say 10 days max, and I'm local so... fingers crossed it'll be quick.
Went to the inaugural Caffeine & Octane here in Jax on Saturday. Very cool.
Old 07-14-2021, 02:38 AM   #2250
lil hoodlum
lil hoodlum's Avatar
No pics, but on my '68 C20 the ammeter was showing the circuit as discharging. I replaced the alternator with a know good alternator that tested good. No change, so I replaced the voltage regulator with an old one that I had laying around. Ammeter then bounced around from charging to discharging. I then replaced the horn relay and voltage regulator with brand new ones and now showing "charging" for the most part... May look at and replace the 53 year old charging circuit wiring harness next...
lil hoodlum is offline   Reply With Quote
