Old 06-07-2021, 05:48 PM   #576
68 C10 Driver
Re: My 1970 GMC “Project Splice”
I did the Raptor Liner on the underside of the cab (over epoxy primer), and will epoxy prime inside the cab and then coat the floor, firewall, and part way up the back with Lizard Skin.
To finish my rust protection, inside the rockers and the void in inside the roof area will be coated with Waxoyl. The truck should never rust again...
68 C10 Driver is offline   Reply With Quote
Old 06-07-2021, 05:50 PM   #577
Kronald_70GMC
Kronald_70GMC's Avatar
That sounds like a solid plan right there. Should be impenetrable.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 06-20-2021, 06:36 PM   #578
Kronald_70GMC
Well there was no progress last week as my Sunday was much too busy with getting Daphne baptized, but this week I have had the afternoon to work on the cab. I have been putting more marglass in the passenger door jamb. It is coming out quite nicely so I hope to be starting with regular bondo sometime early July. I still have to body work out the firewall but I may have to leave it until the bottom of the cab has been finished and painted as I will have to set the cab on the firewall to accomplish that.
I will also have to order my Altman Latches at some point as well. I plan to rebuild my door hinges as well at the same time even though they seem tight. Might as well do it now. If anyone has any good info such as where to buy a good quality rebuild kit and a how to link, that would be much appreciated.
Kyle
IG: kyle_ronald
Old 06-20-2021, 07:45 PM   #579
May70
May70's Avatar
How is marglass to sand compared to rage filler? Ive used short stand products and they are torture sanding
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 06-20-2021, 08:15 PM   #580
Kronald_70GMC
The stuff that I am using is not bad. It's definitely harder to sand than just regular filler but from what I remember the stuff I used to use when I worked in the body shop sanded horrible. I think the stuff I have now is called Pro short strand reinforced body filler.
Kyle
IG: kyle_ronald
Old 06-28-2021, 11:24 PM   #581
Kronald_70GMC
More filler in the passenger door jamb tonight. Not alot of progress as it is quite hot out and it is hard to stay motivated when it's this uncomfortable to work. We are under heat warnings all week. Today was about 32° C and its only supposed to get hotter as the week goes on. By Thursday, we are supposed to be hitting 38° C. Good thing I'm headed to the lake Thursday morning.
Kyle
IG: kyle_ronald
Old 06-29-2021, 10:12 AM   #582
88Stanger
88Stanger's Avatar
Looking great sir!
I hear you on the heat thing! 111F here yesterday and hotter today. I have a mini-split in the shop and it was not happy at the heat.
I am in about the same place with my "66 cab yours looks better than mine though.
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 06-29-2021, 10:18 AM   #583
Kronald_70GMC
Originally Posted by 88Stanger View Post
Looking great sir!
Thank you sir, you got me beat on the heat by a few degrees.
Kyle
IG: kyle_ronald
Old 07-06-2021, 06:47 PM   #584
Kronald_70GMC
Haven't had a chance to work on my truck for a bit but I did swing by and check out my brother's truck on the way home from work today. It's coming along pretty nice! Can't wait till mine looks like this.
Kyle
IG: kyle_ronald
Old 07-07-2021, 10:46 PM   #585
Kronald_70GMC
More filler progress tonight. Passenger door jamb is nearly finished, at least for the Mar glass stage. I found out that the passenger side of the cab may have been involved in an accident of some sort at some point. It would have been something very minor but as I was doing the Ole body work rub down, I felt a few waves and the rounded portion felt slightly flattened. So I got a coat of glass on that as well. I'm looking forward to being done with the glass. I hope that the lightweight filler will go on smoother as I remember it being much easier to apply. We will see.... any way, here come some more boring pictures.
Kyle
IG: kyle_ronald
Old 07-08-2021, 12:47 AM   #586
Scurry67
All that hard work will definitely pay off! I was in the same boat and you just have to take it one day at a time. Have you looked into using feather fill as your filler? It was a lot easier to spray the filler than it was to spread the filler. Keep the updates coming.
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 07-08-2021, 01:35 AM   #587
Kronald_70GMC
I have never used featherfill before. I had thought about it at one point but I already bought a gallon of bondo. I'd it turns out rough, maybe I'll use feather fill for the final coat. Thanks for following along with the build, I will definitely keep the pictures coming but they are pretty boring lol
Kyle
IG: kyle_ronald
Old 07-08-2021, 11:28 AM   #588
Chevys4life
That cab is looking good!!!!
Chevys4life is offline   Reply With Quote
Old 07-08-2021, 06:35 PM   #589
Kronald_70GMC
Thank you! I'm pretty happy with how it's coming out
Kyle
IG: kyle_ronald
Old 07-08-2021, 07:28 PM   #590
72 tigger
72 tigger's Avatar
Good progress- going to be sweet!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 07-08-2021, 07:31 PM   #591
Kronald_70GMC
Thanks. If only I was faster
Kyle
IG: kyle_ronald
Old 07-21-2021, 12:56 AM   #592
Kronald_70GMC
No progress to speak of on the truck. Hopfully soon. Things were piling up in the shop again and it was time for a major cleanup. I scored some more lighting from work so I've been working on that. One thing led to another and next thing you know, I'm painting my severely yellowed out pegboard to nice bright white. That along with the upgraded work bench light and things are very bright now. I also hung a new light on the other side of my shop and fixed/added more lighting along the front by my welding table. At this point, lighting upgrades are complete as I will not have room for any more fixtures.
Kyle
IG: kyle_ronald
Old 07-22-2021, 04:43 PM   #593
cornerstone
cornerstone's Avatar
What a big difference a nice and clean, bright workspace does. Makes a guy wanna go out and get to work again!
I really like your shelves way up high all around the shop. Looks like it would free up more floor space... a good spot to put things that you don't use that often.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 07-23-2021, 12:25 AM   #594
Kronald_70GMC
It sure does make a difference with bright lights, especially during bodywork. The shelves are awesome! I needed to keep as much of my trucks parts up out of my limited work area. I'm getting very close to having it clean. I have a certain standard I need to uphold on account of the wife parking in the one side. Should be back at it again soon
Kyle
IG: kyle_ronald
Old 07-23-2021, 11:54 PM   #595
Kronald_70GMC
Work continues on the cab, more body filler more dust. I needed I small block for some sanding in the door jambs so I found a machined aluminum block I had lying around the shop and used it. It works awesome for what I need.
Kyle
IG: kyle_ronald
Old 08-11-2021, 11:38 PM   #596
Kronald_70GMC
As per the usual summers, I have not been able to drum up much time on the truck. I have however started the process of installing a new top on my welding table that I scored from work. The top that was on there was extremely beat up and very saggy due to the lack of supports in the middle. I will be beefing it up before installing the new top. Hopefully that will be wrapped up by the weekend and I can get back to the feature presentation.
Kyle
IG: kyle_ronald
Old 08-22-2021, 04:14 PM   #597
Kronald_70GMC
I'm gonna have to stop giving myself deadlines during the summer, I never make them anyways. I have finished up the welding table which has cleared up space in the shop so I was finally able to keep hitting up the Mar glass. It is taking much longer than expected to get everything to where I am happy with it. I feel like that is pretty standard when bodywork stage starts. I'll keep on plugging away and hopfully with some luck, I'll be able to move onto regular filler soon. Last picture is a real beauty that showed up at work the other day.
Kyle
IG: kyle_ronald
Old 08-22-2021, 06:34 PM   #598
Kronald_70GMC
Wow you really think you have nice straight sheet metal until you get the filler sanded.
Kyle
IG: kyle_ronald
Old 08-23-2021, 12:42 PM   #599
Chevys4life
You are doing a great job on your cab!!!!
Old 08-23-2021, 01:43 PM   #600
Kronald_70GMC
Hey right on! Thanks man
Kyle
IG: kyle_ronald
