Old 07-09-2021, 07:26 PM   #1
402Bowtie
402Bowtie's Avatar
NOS Parts Question--Vent Window Channels
Posting this here as I'm hoping some NOS parts guys can help me out...
Has anyone seen NOS Vent Window Channels without the "A Bailey Product" stamping?
I have some "NOS window channels" in opened wrappers that do NOT have the stamping shown below. Every NOS (& used OEM) one I've seen has had the stamping. I'm wondering if mine perhaps aren't NOS GM parts.
The only difference I can think of is that the ones I have without the stamping are p/n 15662134. The ones with the stamping that I have seen in the past have always been p/n 3936809. Anyone have p/n 15662134 on the shelf that could look for the "A Bailey Product" stamping?
I'm not looking to sell them, but just to be fully compliant with board posting rules, I will sell the vent window channels for $1,000
402Bowtie is offline   Reply With Quote
Old 07-10-2021, 11:45 AM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: NOS Parts Question--Vent Window Channels
I have a set or two with the Baily inscription. I believe they are GM contracted parts source. If you use them to rebuild a set of vent windows. The rebuilder will have to drill all the holes for the attachment of the frames. But, they are last like a OE GM part, not like aftermarket insets.
Check with Roger Koop, he rebuilds nice vent windows.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 07-10-2021, 12:08 PM   #3
402Bowtie
402Bowtie's Avatar
Thanks David. Do you know if you have any NOS ones without the Bailey inscription?
Old 07-10-2021, 05:08 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I just packed them away.....Ha!
I'll double check, but I don't recall seeing a stamp on the original bar, I did strip them. Maybe the old are Bailey with or with a tag. From one opinion, newer GM Baileys are square on top like the rest of the bar, while originals are cut 45ish. And yeah to the trained eye you'll see it, but it's not the worst thing. Old is always better seems. For instance, I like rivets better on original spot mirrors. Been a while since I've pulled them out, I remember the rivet was better and/or workmanship.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 07-10-2021, 05:20 PM   #5
Accelo
Accelo's Avatar
I have an NOS set and they have the inscriptions like you mentioned.
Accelo is offline   Reply With Quote
Old 07-10-2021, 05:29 PM   #6
402Bowtie
402Bowtie's Avatar
By "original" do you mean the ones that were installed on the truck at the factory...as in a "used" channel? I have some used ones and they have the Bailey inscription. If you have some NOS ones with p/n 15662134, I would definitely appreciate you seeing whether or not it has the Bailey inscription.
Thanks Accelo. What part number is on the packaging?
My question ultimately is does anyone have p/n 15662134 with the Bailey inscription? I bought some 15662134 parts described as NOS but wondering if they may have been swapped with some repro's, as they don't have the Bailey inscription.
I'm not sure which part number came first...3936809 or 15662134. I've seen some used ones with the Bailey inscription and every 3936809 part I've seen has had the inscription....so maybe 15662134 was a later run by a different vendor?
Old 07-10-2021, 07:54 PM   #7
71CHEVYSHORTBED402
You're right, the original factory installed bars say A BAILEY PRODUCT. And yes, seems the newer NOS Bailey's are square on top, where the original installed bars are cut at an angle.
My NOS Bailey’s are 3936809. The part number doesn’t come up for light trucks, but does medium, which isn't that unusual, it's the same cab. Oddly 15662134 doesn't come up under parts search, though sure a lot of hits on the web otherwise.
OT: Where 3936809 shows in the parts book reads "Excludes Tilt". You got me.
Old 07-10-2021, 09:00 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
John I have two NOS sets. One set is stamped. One set is also pre-drilled for the vent window frame rivets. It’s interesting that some were pre-drilled.
Old 07-10-2021, 09:49 PM   #9
402Bowtie
402Bowtie's Avatar
Pete, so is one set not stamped? What are the part numbers?
Old 07-10-2021, 09:55 PM   #10
402Bowtie
402Bowtie's Avatar
Hmmm interesting. Thanks for the input!
Old 07-10-2021, 10:12 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Correct.
The set with wrapper remnants has p/n 3936809 and it is stamped.
The non-stamped set is without a wrapper. It has predrilled holes and the tab that’s folded out to nest with the window frame.
I’d say some were stamped others not. Some predrilled others not. Were channels ever reproduced with the felt inserts embedded in the track like OEM? I don’t believe so but maybe I’m wrong.
Old 07-10-2021, 10:59 PM   #12
Mitchell pendley
I have a set of nos p n 3936809 an they have the bailey stamp on the back an no pre drilled holes.
Mitchell pendley is offline   Reply With Quote
Old 07-12-2021, 03:49 PM   #13
71CHEVYSHORTBED402
Correct.
You mean the vent window bars Pete? If so my NOS came with the felts installed, but son of a gun the holes for the bracket aren't pre-drilled. Not sure about the rest of the rivet holes, I didn't think to look before I packed them up again.
Old 07-12-2021, 04:05 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Hi Tony - Yes, the division bars. I've not seen repros that have the fabric/felt guides affixed to the metal channel itself as shown above. Rather, I've seen repro guides/inserts that are designed to be placed inside existing OE metal channels at the time of rebuild. My point is, if metal channels have the felt/fabric guides affixed these are likely NOS/OE.
Old 07-12-2021, 10:39 PM   #15
71CHEVYSHORTBED402
Ooops, I thought you meant later GM. I bought felts for original and will let whomever rebuilds them decide that or drilling the NOS. One of the original bars needs a little attention, but not bad for having been T-boned
Old 11-08-2021, 01:46 PM   #16
402Bowtie
402Bowtie's Avatar
I saw these on ebay... I think it confirms my guess in the original post: the 15662134 variation did not have the stamping on the one side... At least it is another data point pointing in that direction.
