![]() Join Date: Apr 2005
Fleetside Bed Inner Rear Splash Shield Mounting?
Hi Guys, I purchased a reproduction bed with a steel floor and am trying to fit the rear splash shields that mount behind the rear tires. The bedside has a weld nut for one of the mounting features but the bed floor brace only has through holes (see arrows). Should a weld nut have been used in these locations? Or am I missing something. Thanks for your help.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675 2011 Dodge Ram 1500 2012 Camaro ZL1 |
![]() Join Date: Jul 2016
Re: Fleetside Bed Inner Rear Splash Shield Mounting?
It never made sense to me but in that position gm used a 5/16 self tapping machine screw, it's about 5/8 to 3/4 inch long
Thanks for the fast reply. I'm not a big fan of those self tapping deals either but if that's what they used I'll give it a try. Did the screw have a hex head or round head phillips?
All about them K’s
![]() Join Date: Jun 2014
I've only seen hex heads.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Agreed hex head for sure
The bolt is unique to that location and not used anyplace else. It also doesn't have an integrated washer like most bolts on the truck, but I do think a flat washer is under the bolt, I would have to go look to make sure.
I think you could take a regular 5/16 bolt like one from the front clip with integrated washer and use a cut off wheel to slice a cutting groove in the threads and it would bite into the sheet metal and tighten down. |
And btw, I installed those splash shields last week in my new repro bed with a wood floor, it took an hour per side or so and they fit like crap...
I also test fitted a used original splash shield and it didn't fit any better, gap between shield and fenderwell
![]() Join Date: Jul 2015
Just gave an attempt to put mine back in after coating them. The holes are stripped out and I have to find a larger size diameter self taper.
Or if anyone has more thoughts on getting these in better?? Mine do not fit well either. |
If I had to fix that I would cut a 1/8" plate, drill holes and install J nuts,slip plate in crossmember
Thats is a great idea. Will be getting them in soon!
I was thinking those rivet nuts like the ones shown might be a good option instead of the self tapping bolts. I agree that the panels do not fit well. I have mine sectioned in three pieces and am trying to piece them back together.
That is a good idea...some types of those you can set without a special tool too
#14 | |
![]() Join Date: Jun 2005
Thanks, Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#15 |
Getting ready to paint lower panel on 70 K10 , two tone (white/blue/white). Anybody know how the rear inner splash shields were painted? If they were painted? Body color or?? thanks, Mav
#16 |
I agree the shields are crazy. I had to use a stretcher and a BFH to contour it to match up. Sorry I can't remember if my bed rail had thread inserts or not.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
#17 | |
QUOTE=Peanut74;8944397]I agree the shields are crazy. I had to use a stretcher and a BFH to contour it to match up. Sorry I can't remember if my bed rail had thread inserts or not.[/QUOTE] YES crazy here too ... wonder if they are different for wood vs metal floored bed? They are OE I pulled from metal & not even close to fitting on wood.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#18 |
Active Member
![]() Join Date: Jun 2021
Same here my C20 has them black/rusty
