Old 07-13-2021, 10:29 PM   #1
68350
68350's Avatar
How good are the repop fenders?
Looking at going with some repop front fenders as rust free originals will probably be out of the question to find. Is the fitment on par with most repop stuff? I plan on using AMD probably for the source unless someone has other sugggestions
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 07-13-2021, 11:29 PM   #2
jweb
jweb's Avatar
Re: How good are the repop fenders?
A few years ago when I was looking for fenders I bought a few different brands. I wasn’t impressed by the fit.
The main issue was the piece spot welded in around the headlight. They have large gaps and don’t line up with the grill surround. Not sure if I still have pics, I will check.
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 07-14-2021, 10:12 AM   #3
jmarkha1
The '65 front fender I changed was not "too" bad. It had alignment issues along the top mounts - I removed the inner skin at the top of the fender and welded to the repop. The fit to door leading edge and the front was actually very good considering. The steel felt a little thinner but maybe just because it had no underseal or paint :-)
jmarkha1 is offline   Reply With Quote
Old 07-14-2021, 11:51 AM   #4
joesscamaro
I used repop on my truck and they required some tweaking. As mentioned, the seam on the front edge of them was sub-par as far as the gap being consistent. I welded that seam up on mine anyways...so, no real harm. The worst part was the lower aft mount on mine. When bolted up it was probably 1/2" inset from the door leading edge. I cut the lower portion of that brace and basically "gapped" it accordingly to get it to sit flush with the door skin. Hope that last sentence makes sense. If I had to do it over again, I would just buy the rear repair section and weld in as needed.
joesscamaro is offline   Reply With Quote
Old 07-14-2021, 05:27 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
From another post someone said AMD's tolerable - https://www.autometaldirect.com/body...ents-c-23.html
Nothing is going to match OEM.
Old 07-14-2021, 07:03 PM   #6
68350
68350's Avatar
I ended up going with Wes (classicheartbeat) since he had the rest of the parts I need as well. I will update back when I install the repops and let you know how they fit
Old 07-15-2021, 11:42 AM   #7
vince1
I was given a pair of fiberglass fenders for whatever reason I don't know but they sure worked OK on my beater truck. I'm not body shop aware enough to know if the fit is bad or good but I do remember having to do a bunch of shimming on the lower portions.
vince1 is offline   Reply With Quote
Old 07-17-2021, 11:57 AM   #8
Pitpig
Got a right front Triplus from classic parts, fit fine. All the holes lined up, seemed the same gauge steel. Not restoring a Rolls
Pitpig is offline   Reply With Quote
