Old 06-18-2021, 08:45 PM   #1
Asshat
Asshat's Avatar
Tach suggestions, location, but not in dash
Wondering where you guys put your tach? Mounted under the dash or clamped to the column?
Open to suggestions!
I know it would be nice to install in the dash, however, I just don’t want to take it apart right now.
Thanks!
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 06-18-2021, 08:55 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Tach suggestions, location, but not in dash
I clamped mine to the column and I made it's wiring into a little harness with a plug kit on the end so I could easily remove it for a show or whatever. Thing is I never remove it anyway.
AcampoDave is offline   Reply With Quote
Old 06-18-2021, 09:02 PM   #3
Asshat
Asshat's Avatar
Any pics? What brand? Did you buy it on Summit or someplace like that?
292, 4-speed
Old 06-18-2021, 09:42 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
My FiL mounted a tach at the far left of the dash at the bottom of the A-pillar.
~Steven
Simi Valley, CA
Old 06-18-2021, 10:44 PM   #5
cwcarpenter98
cwcarpenter98's Avatar
I mounted mine on the column, but I just zip tied it. Haven't had a zip tie break at all in the approximate 4 years it's been there. Also, if I need to remove the cluster, all I have to do is rotate it over to the side
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-18-2021, 11:17 PM   #6
AcampoDave
AcampoDave's Avatar
Its an old Suntune mini that i bought brand new waaay back when. It came with a big ol' hoseclamp for column mounting. That location provides for a quick unobstructed view too. I kind of use it as a speedometer since mine is hopelessly broken anyhow.
Old 06-18-2021, 11:58 PM   #7
Asshat
Asshat's Avatar
Can you guys recommend a good one?
292, 4-speed
Old 06-19-2021, 02:19 AM   #8
SOON2BLAZE
SOON2BLAZE's Avatar
You will need a tach for a 6 cyl. Simplest solution is one from eBay that doesn't require a transmitter box. I would look at a Moon Eyes if you want big one or a small one such as the Super Pro 81316. The small one could also be placed in your cluster at a later time with another face on it.....
search 81316 and there's a NIB for 60. shipped
SOON2BLAZE is offline   Reply With Quote
Old 06-19-2021, 09:02 AM   #9
cwcarpenter98
I used an Equus tach that I got from the parts store. One of the LED backlights failed, but other than that, it has worked well for me. It can do 4, 6, or 8 cyl and points or HEI dizzys
It was fairly inexpensive back then
Christian Carpenter
Old 06-19-2021, 12:41 PM   #10
Paul Y
I used this one on my 56 PU.
Does 4, 6 and 8 cylinders. Wouldn't necessarily trust it in a high winding 8K small block but in a steady away 6 cylinder it will do you fine.
Plus it looks the part.
https://www.mooneyesusa.com/MOONEYES.../mpg5000tm.htm
As for location attach it to the column as per others or stick it on the top of the dash and use the holes for the speaker to run the wires and secure it.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 06-19-2021, 12:45 PM   #11
AcampoDave
AcampoDave's Avatar
I was googling around one day for a friend trying to look for a Suntune tach, but all I found that was close to mine was Actron/Bosch. The reviews on Amazon are pretty strong though https://www.amazon.com/s?k=bosch+tac...l_5ttj5aczp2_e This one most closely resembles mine with regard to it's appearance and 2 5/8 inch size. https://www.amazon.com/Bosch-SP0F000...4121142&sr=8-4
Old 06-21-2021, 02:15 PM   #12
Klas
Junior Member
Klas's Avatar
I made a cluster housing out of fiberglass so I could mount tach, temp, oil pressure and volt gauge. Gauges are small but readable.
Klas is offline   Reply With Quote
Old 06-21-2021, 10:01 PM   #13
vin63
It's Better With Nitro
vin63's Avatar
Here's where I mounted mine.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-21-2021, 10:38 PM   #14
cwcarpenter98
I forgot I had mounted it on the bottom of the dash for a bit before I moved it to the column. I like the column mount better because I don't have to take my eyes off the road as much to see the tach on the column compared to below the dash.
Sorry for the sideways pic
Christian Carpenter
Old 06-22-2021, 06:59 AM   #15
Paul Y
Very nice Vin!
Do you really swing that Poncho to 6K ++?
P.
Woody's Build -
Old 06-22-2021, 08:41 AM   #16
vin63
vin63's Avatar
Thanks! It made peak HP at 5900 RPM, and I have taken it up to there a few times.
Originally Posted by Paul Y View Post
Very nice Vin!
P.
Old 06-27-2021, 09:50 AM   #17
my04
my04's Avatar
On the column, rotated to the right side.
1966 Custom Camper -327, 3OTT
1968 Chevrolet K20 - 350, 4 speed
1972 K10 SWB - 400, 3OTT
2003 Corvette Z06 - LS6 350, 405HP
2004 Tahoe LT
2015 Silverado 2500HD - 6.0L V8
my04 is offline   Reply With Quote
Old 06-30-2021, 10:21 PM   #18
Asshat
Asshat's Avatar
I picked up an Auto Tune tach, hopefully, it will work.
292, 4-speed
Old 06-30-2021, 10:28 PM   #19
AcampoDave
AcampoDave's Avatar
Cool, it'll be good to know your freeway rpms and shift points and all that. I'm kinda curious myself since you have the overdrive and all, maybe you can keep this thread alive by letting us know.
Old 06-30-2021, 10:31 PM   #20
Asshat
Asshat's Avatar
Definitely!
I also just found out a friend of mine has a good friend that owns a rear end/differential shop in LA. Now I have some place to go, and hopefully, a good source of info!
292, 4-speed
Old 07-19-2021, 09:53 PM   #21
slepysal
slepysal's Avatar
A little late but here is mine
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-19-2021, 11:41 PM   #22
AcampoDave
AcampoDave's Avatar
Now that this thread is back, how did the tach work out Mr Hat? What are your freeway rpms? Overdrive vs. 4th gear and all that
Old 07-20-2021, 12:06 AM   #23
Asshat
Asshat's Avatar
Hey Dave, it was a busy few days and I have not yet had the truck out on the highway. After 4th of July, the old wagon and BBQ ended up in the back of the bed. Gotta get it stored before I can drive the truck. In addition, my 2nd grandchild was born on the the 15th!
I know I’m just making excuses, best I can do right now. I do mean to keep this thread going and get the rpm info out there, I am also curious what rpm I will be running at 65.
292, 4-speed
Old 07-21-2021, 08:03 AM   #24
MT65
For your rpm at unknown speeds, go to tiresize.com, there are some equations there to help you, put in your known values, it will give you your unknown…..easier than mounting a tach….
MT65 is offline   Reply With Quote
Old 07-22-2021, 10:21 AM   #25
Paul Y
Yea... But a tach is COOOOOOLLLLLLL.
P.
Woody's Build -
