Old 07-22-2021, 06:43 AM   #1
dmjlambert
dmjlambert's Avatar
Re: core support
That is also available as an aftermarket patch panel. I don't know if it's any good. https://www.brotherstrucks.com/1967-...tinfo/RSP72RH/
Old 07-22-2021, 11:58 AM   #2
64k10burb
64k10burb's Avatar
Re: core support
Originally Posted by LockDoc View Post
Moved it for you.
LockDoc
Thanks Doc!
Originally Posted by truckster View Post
I'd replace it. But you should be able to just flip it if you really want to do some fabricating.
OK, Thank you Truckster!
Originally Posted by Richard View Post
If you want to fix check this out https://67-72chevytrucks.com/vboard/...t=core+support Not sure if he has any left.
Great, thanks!
I hadn't seen that before, Thanks!
Brian
1969 c-10 short/wide/6L LS swap
1964 k10 suburban project
1964 Falcon sedan delivery rescue project
64k10burb is offline   Reply With Quote
