Old 10-02-2020, 03:33 PM   #1
kens65fb
Original Throttle linkage to Edelbrock Carb?
Has anyone adapted the original throttle linkage to an Edelbrock Carb?
Any pics?
kens65fb is offline   Reply With Quote
Old 10-02-2020, 03:53 PM   #2
forestb
forestb's Avatar
Re: Original Throttle linkage to Edelbrock Carb?
Here is one link where that has been answered.
http://67-72chevytrucks.com/vboard/s...rottle+linkage
If you do a smart search for throttle linkage you will find several threads on the subject.
forestb is offline   Reply With Quote
Old 10-02-2020, 05:10 PM   #3
doobiebro
doobiebro's Avatar
I bought a round stock 1/4" with Mr. Gasket linkage bushings. Works great!
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 10-04-2020, 09:23 PM   #4
The Sub
The Sub's Avatar
I Used the original linkage.
http://67-72chevytrucks.com/vboard/a...1&d=1601860722
:Ito:Jim
The Sub is offline   Reply With Quote
Old 10-06-2020, 07:33 AM   #5
notsolo
notsolo's Avatar
[QUOTE=doobiebro;8817097]I bought a round stock 1/4" with Mr. Gasket linkage bushings. Works great!.........I must have saved your photo, posted on another thread, nice clean set up.
notsolo is offline   Reply With Quote
Old 07-18-2021, 06:54 PM   #6
AcampoDave
AcampoDave's Avatar
If I wanted to do my throttle rod like the pic in post #4, what parts do I need to buy? As of now I have something a bit substandard rigged up to the smaller hole on the carb arm with a cotter key. Maybe it was my stock 2 bbl stuff. I thought about this one, just not sure if the threads on the stock rod are 1/4-28. https://www.summitracing.com/parts/afc-10171
AcampoDave is offline   Reply With Quote
Old 07-24-2021, 02:58 PM   #7
AcampoDave
AcampoDave's Avatar
A few things I learned in trying to hook my stock V8 pedal bell crank to the large hole on the carb like this https://www.fordmuscle.com/archives/...rottleLinkage/
The threads on the stock linkage rod are 1/4 -32 so I made a 1/4-28 rod as seen in the tutorial and bought the heim joints and stuff. Thing is, the geometry with a straight rod didnt work because of the arc in the carbs travel and no matter how I bent or altered the rod (J bend, Z bend etc) i never could get full trave on the carb. I could set it up connected at full throttle and the carb wouldn't fully close when I let go. Conversely, if I set it up for the carb at idle, it would only pull part way open. I believe the problem lies in the fact that the large hole begins pulling back and downward as it crosses the apex mid throttle when you floor it.
So now its back to this which wiggles a bit but gets full travel
