Old 07-19-2021, 10:38 AM   #1
blazer2007
search for air bag leak
I have a leak somewhere on my fr. bags. The 2 bags are on one switch so the line goes from the switch to the fr. driver side and tee,s off to to the fr. bags. Has worked well like this for years except a pesky leak. The dr. bag looses air first and then takes away the air from the pass. bag. So ,is this telling me the leak is somewhere on the pass side ? Hope you understand my little story
blazer2007 is offline   Reply With Quote
Old 07-19-2021, 11:02 AM   #2
SCOTI
SCOTI's Avatar
Re: search for air bag leak
In this situation, you'll need to isolate for that determination.
My approach would be to set each side up for a manual fill & testing. A Schrader valve @ each side & some short lengths of air line will allow you to get the task done. Fill them to your typical pressures then wait & watch.
If one side doesn't start losing air psi, that would indicate the leak is somewhere in the supply side from (after) the switch.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-19-2021, 11:19 AM   #3
blazer2007
thanks, I don,t know the dynamics of air pressure. I wasn, sure that maybe the leak was on the pass, side and the dr. bags was loosing air to compensate for air loss on pass. side being that bag is at the end or the line. Was hoping it was telling me it was dr. bag. It takes a week to lose about 40 psi from 100 psi.
Old 07-19-2021, 11:45 AM   #4
kwmech
soapy water in a spray bottle
kwmech is online now   Reply With Quote
Old 07-19-2021, 12:08 PM   #5
blazer2007
soapy water didn,t tell anything ,I thinking is fitting on bag which can,t get to . That,s why I was hoping the gauges was telling me which one
Old 07-19-2021, 12:42 PM   #6
tinydb84
tinydb84's Avatar
I had a leak in one of my rear bags and messed with the fitting for weeks before it dawned on my to check the actual bag.
I changed my fittings to directly screwed in schrader valves (you can get two for a few bucks on amazon) like Scoti said and then switch the side to side after a day to make sure it wasnt them. The bag was leaking but it was so slow I couldnt tell where it was leaking-even with soap and water.
David
Instagram: myfabguy
Old 07-19-2021, 01:07 PM   #7
SCOTI
SCOTI's Avatar
Yep. I need to do this for my dually as the driver rear likes to bleed down over a weeks time. I need to get it on jack stands & isolate the air supply to get it done which requires the effort of removing things to access the air fitting on top of the bag (in close proximity to the bottom of the bed floor).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-25-2021, 11:59 AM   #8
Ziegelsteinfaust
In ac we use this, and with enough patience you can find very small leaks.
https://www.amazon.com/Nu-Calgon-418...on+leak&sr=8-3
Ziegelsteinfaust is offline   Reply With Quote
Old 07-26-2021, 10:06 AM   #9
blazer2007
Once I get the bag out how can I test the fitting when there is no weight on the bag. I don,t think you can put too much air in on the bench. I can think of stupid ways that could cause damage or injury.
Old 07-26-2021, 10:41 AM   #10
SCOTI
SCOTI's Avatar
I've tested mine @ psi's the bag would see under load. ~30psi will show if there's a leak.
I use a Schrader valve & a short piece if airline for pressurizing the bag. Spray w/dish-soap water or submerge the bag in a container (tub) of water.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-27-2021, 10:26 AM   #11
blazer2007
Thanks again, I guess I have to go to work now
