#29 |
Re: 2 inch drop spindle or maybe not??
@kglowacky,
Was the leaf spring & a-arm hardware tightened when extended or under compression? They need to be tightened when under compression or it will bind things. Binding leads to mis-leading measurements. Loosen things up & retighten w/full weight on the tires. Re-measure before you start shimming body panels.
| Bookmarks |
