Old 07-15-2004, 03:24 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Question Gas door on bed side in front of tire?
Has anyone installed a gas door from a later model truck on the bed side between the rear tire and the front of the bed with the gas tank mounted between the frame rails in the rear? I'm not trying to make a show truck so I am looking more for convenience like the late model trucks.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 07-16-2004, 11:55 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
drive shaft gets in the was of putting it in the frame below the bed but i was gonna do away with the floor anyway.
sneakysnake is offline   Reply With Quote
Old 07-16-2004, 12:02 PM   #3
sneakysnake
Opps I read it again, be a lot of plumbing to run it back, but I put a Koenig bed off a ford on a chevy and it had a good run as long as you can keep it going down hill it will flow
Old 07-17-2004, 12:53 PM   #4
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
mocwon,
I am working on your tank today (7/17). Do I need to move the filler to a new location on thre tank?? I haven't cut any holes in the tank for the filler. I will wait until I hear from you. Later, FCG
FuelCellGuy is offline   Reply With Quote
Old 07-17-2004, 06:48 PM   #5
mocwon
Keep On Truckin'
mocwon's Avatar
Originally Posted by FuelCellGuy
mocwon,
Thanks. I would like to put the fuel door between the rear tire and the front of the bed on the driver's sid like is done on late model trucks. My body shop guy tells me he thinks it can be done. What do you think? Have you ever seen that done?
Thanks, Greg
Just Passin' Thru
Old 07-17-2004, 08:36 PM   #6
GMC Jim
GMC Jim's Avatar
I had the bedside doors filled when I had the truck painted.....removed both saddle tanks; cut off and filled the side pipe and moved the fill pipe to center front of tank... Welded into position at about a 45 degree angle... The fill pipes are in the wheel well ahead of the rear tires. And yes... I did clean the tanks thoroughly plus filling with water before any cutting or welding !!!.. I never did like the looks of the side doors.....
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
