Old 04-27-2015, 01:24 AM   #1
sanford66
sanford66's Avatar
Who sells the best turn signal switch?
Need to replace the turn signal switch in my daily driver 66 i just picked up. Who sells the best quality switch or what brand should i look for? Of course my turn signals are not working but my brake lights are a no-go also. According to the wiring diagram the white wire from the brake light switch runs thru the turn signal switch, not sure if that is the problem or not. Anyway thanks for the help. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 04-27-2015, 09:22 AM   #2
1963c-10
1963c-10's Avatar
Re: Who sells the best turn signal switch?
Classic Industries
1964 Short bed trailer
Old 04-27-2015, 09:54 AM   #3
ACK
ACK's Avatar
If it's a daily driver, purchase a Wells, part# SW3027.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 04-27-2015, 12:46 PM   #4
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
I tried to save money and used one that Grumpy's truck parts in Phoenix, Arizona sold that was an aftermarket that lasted about a year. I took it apart and repaired the contacts and that lasted about three months. I then order this one AC DELCO Part # D6202 and has been in my truck for 6 years now. They are more money than the aftermarket ones and getting harder to find but well worth the extra money.
66Gilbert is offline   Reply With Quote
Old 04-27-2015, 12:49 PM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
American Auto Wire is also a good one.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-27-2015, 01:46 PM   #6
Mutt65
Do you know if Grumpys is still around? last I heard they had closed down before I had the chance to go check it out
65 c20 fleet sbw lwb 307 olds-Color Rust, white household latex paint, black primer, grey primer and rust
She aint fast, But she moves forward with great dedication, that's about it, also doesn't stop either
Mutt65 is offline   Reply With Quote
Old 04-27-2015, 08:58 PM   #7
66Gilbert
66Gilbert's Avatar
Grumpy's closed down 2 or 3 years ago.
Old 04-27-2015, 11:49 PM   #8
argonaut
argonaut's Avatar
I had the same experience. It wasn't fun when my brake lights and turn signals stopped functioning properly. Got the oem style ac delco and it is much better quality.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 04-28-2015, 03:59 PM   #9
nxtruck
nxtruck's Avatar
X2. I had nothing but trouble with the cheaper switches. Bought the AC Delco switch from Classic Industries and no more problems.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 04-29-2015, 06:40 AM   #10
ImpalaJim
ImpalaJim's Avatar
http://www.ebay.com/sch/grumpystruck...88.m1543.l2654
ImpalaJim is offline   Reply With Quote
Old 04-29-2015, 09:37 AM   #11
Chevy Fleetside
didn't know Summit sold these and at a good price too. I have an autowire switch in my truck for a few years now. Good quality and GM Tooled. http://www.summitracing.com/parts/aw...s/applications
Old 05-13-2015, 12:19 PM   #12
akqj9
how hard are these to install? What are the steps? thanks
akqj9 is offline   Reply With Quote
Old 05-13-2015, 01:08 PM   #13
1963c-10
1963c-10's Avatar
Starts with unplugging the switch from the harness under the dash and removing the steering wheel. Once the wheel is off, you will have access to the screw that holds the turn signal lever on. Remove the lever. There are three screws that hold the turn signal switch in place. I find it easier to also remove the column cover ( 2 screws under the column)to allow easier access to reroute the switch couplings back through also. The switch cup that mounts to the column and holds the turn signal switch will rotate counter clockwise (part 36 in the 2nd diagram) and then you can remove the switch from the column. Reinstalls in the opposite order.
The 2nd diagram is from a 71 column, but the parts are in the correct order. Hope this helps.
Old 06-10-2015, 12:31 AM   #14
moondog64
AC Delco D6202 from walmart.com for $78. Free shipping
moondog64 is offline   Reply With Quote
Old 06-11-2015, 01:00 AM   #15
sanford66
sanford66's Avatar
Wow, Walmart. I had to look it up for myself, that would be the last thing I would expect to see on Walmart.com. I was thinking about ordering the "premium" switch from Classic Parts only because I need some other stuff too. Are their switches any good? Thanks for all the help guys. Joe
Old 06-11-2015, 12:14 PM   #16
newbe351
A little off topic, but as I understand it, the '66 GMC uses a 1963 model turn signal switch. Can anyone confirm this or not before I start ordering parts and tearing things apart?
newbe351 is offline   Reply With Quote
Old 06-12-2015, 08:40 AM   #17
slorio
slorio's Avatar
Newbe351:
That's correct on the 66 GMC using the same switch as the 63 Chevy.
regards,
steve
New Orleans
slorio is offline   Reply With Quote
Old 08-06-2021, 01:19 PM   #18
Tance52
Tance52's Avatar
I bought a brand new switch from "Classic Parts of America" but it should probably be called Classic Parts of China... lasted a total of 56 miles. After reading the previous posts in this thread the "AC Delco" switch had good reviews so I found one on Rock Auto. After ordering I realized they had substituted some Chinese junk for my "AC Delco" search so I was tricked again. Yes, my fault for not staying alert and questioning every step.
Tance
Tance52 is offline   Reply With Quote
Old 08-07-2021, 08:57 AM   #19
vince1
I believe mine came from Classic industries a number of years ago but I don't use the truck much. So far it's been good.
vince1 is offline   Reply With Quote
Old 08-07-2021, 10:18 AM   #20
Chevy Fleetside
I have had my truck for over 8 years now and the American Autowire Switch is doing fine.
