Fabricate till you "puke"
Re: toe in with my 69?
Thanks guys, I think its pretty straight forward on the center up.....& a pic was worth 1000 words 68
From that point, I will assume that it is just a matter of keeping the LH &RH tie rod assys to the same lenght , while setting the toe? longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
| Bookmarks |
