Moderator
![]() ![]() Join Date: Aug 2011
Re: toe in with my 69?
I did the same thing.
Just had mine aligned and they used the arc/degree BS their all doing now. Anyway I went home and checked it had 1/16" toe in. Did a slight tweek and now have 1/8". Drives better on these terrible roads around here (farm to market) but on good roads it's great for what it is.
Fabricate till you "puke"
Thanks again to ALL....yes I do agree to the 1/8 inch toe in . At speed, & I should not say (about 2 1/2 times the legal limit of 55)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#3 | |
