#826 |
![]() Join Date: Aug 2013
Re: Facebook Marketplace finds
#827 |
1972 C20 3/4 ton Super Cheyenne Camper Special 8 ft long bed 2 wheel drive 350 motor th350 transmission.
It runs and drives and stops. We have a title and the tag is current. It is a 3/4 ton C20 Camper Special which means that it has a leaf sprung DANA 60 rear axle. Has a really strong motor will probably do burnouts. We also figured out it has a 4.10 rear gear. We went trough the column and it now works perfectly. The shifter is the way it was new and the turns signals work. Even the hazards work. It has a brand new windshield and now has wiper blades. This is a project for sure but it's a drive it as you fix it type of thing. The engine is strong and the transmission shifts perfectly. It does have some rust in the floor but I've seen a lot worse than this. We put a new master cylinder on it but the rear brakes aren't really working well. All trades will be considered but cash is king. https://www.facebook.com/marketplace...f-97eb30068caa |
#828 |
#829 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#830 |
#831 |
#832 |
#833 |
#834 |
#835 |
I NEED 3500 TODAY
1982 GMC Sierra 6.2 diesel 4x4 Runs and drives great. The Truck was sitting for the last 17 years but After putting 2 new battery’s, a new fuel pump, duratherm glow plugs, all new rubber fuel lines, coolant flush and some fuel it is running and driving great. It does leak a very small amount of oil ( drips) nothing crazy. The Truck is pretty straight inside and out. The usual cracked dash top and carpet peeling off the lower door panels for the interior. Other than that the insides in good shape. As for the exterior. There is a dent along the drivers door body line which could be fixed pretty easily before paint. the drivers side fender does have a really big dent which I don’t think would be worth trying to fix vs replace. Other than very very small “dings” the truck is pretty clean and would clean up really nice with a coat of paint. The tires are shot so I wouldn’t recommend driving far on them. https://www.facebook.com/marketplace...3-646e798a61f7 |
#836 |
Very clean all original has rallies in the bed of the truck runs and drives has 350/350 drive train yes it’s a short bed asking 8k https://www.facebook.com/marketplace...3-646e798a61f7
#837 |
#838 |
#839 |
https://www.facebook.com/marketplace...16085760%22%7D 15 inch rally wheels 15 x8 fits squarebodys and most gm vehicles with a 5 bolt pattern. Comes with beauty rings and center caps asking $500
#840 |
ASKING $29,000
UNRESTORED / 33 OPTIONS - 1985 SB Chevrolet Silverado K-10 History – brief summary – lots more but kept it short. The Truck was purchased by Spencer Flichum in Mt. Airy North Carolina in 1985. He was a farmer and industrial machinist. He purchased the truck as his “going to town” truck (I talked with him and he told me this story). It remained in his ownership well over a decade and then it made it to California into the car collection of the inventor and owner of Mother’s Car Wax. I purchased it from him. 129,000 original miles but it could pass as 29,000. https://www.facebook.com/marketplace...3A108%7D%22%7D |
#841 |
#842 |
#843 |
#844 |
#845 |
#846 |
https://www.facebook.com/marketplace...d-857abc029c1d Very nice looking, running, driving ‘79 c10. 350/350 turbo. All original paint & stainless. New brake calipers, hoses, ceramic pads, tank/sender, crossover, tune up. 81k qoriginal miles, Has 3/2.5 drop. Nice sounding dual exhaust. Has minimal rust but still looks great. Original paint, no bondo. Truck has all original drive line & is all stock except for I put drop spindles, shackle drop, tires & rims, & dual exhaust. I have all the stock parts including original rims, tires, hub caps, & a spare set of tires for the new mags all palletized. Truck is a blast to drive. I wouldn’t hesitate to take it cross country with out even popping the
#847 |
#848 |
#849 |
1968 chevy 1 ton dump truck, v8 motor, 4 speed, pto for dump, work good, motor runs and sounds good. Brakes work when pumped. Cab has rust. Don't know about mileage $2500. https://www.facebook.com/marketplace...a-23d7c2408953
#850 |
