Old 08-15-2021, 12:13 PM   #1
MikeB
MikeB's Avatar
What is this wire?
When I pulled out the instrument panel 6 weeks ago, I ether took this off the back or it had just been hanging there. (In other words, I forgot!)
The black wire (probably 12 gauge) disappears up the steering column. The lug on the cylindrical terminal doesn't have continuity with either of the light bulb terminals.
So what is its mission in life?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-15-2021, 12:28 PM   #2
sick472
sick472's Avatar
Re: What is this wire?
I'm betting that is the fiber optic cable that illuminates the shift indicator on top of the column and not a wire. If so, it should plug into the back of the gage cluster where it gets its power. I'm not sure what hole it goes in, but it would be one that is powered up when the lights are turned on.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 08-15-2021, 12:36 PM   #3
MikeB
MikeB's Avatar
That makes total sense and I feel like a dumb a$$. Pretty high tech for 1969.
Don't remember if the gear indicator ever lit up, but at least I know how to check it now. Thanks!
Mike
Old 08-15-2021, 12:39 PM   #4
Mts67C10K20
Mts67C10K20's Avatar
Agree with sick472
The bulb gets power from the clucter when installed
Fiber optic to indicator...dont bend it...
Mts67C10K20 is offline   Reply With Quote
Old 08-16-2021, 02:17 PM   #5
va72longhorn
va72longhorn's Avatar
Fyi, it doesn’t actually “ get power” from anywhere. It “looks” at an illuminated light source (instrument bulb) and transfers the light through the clear conductor. When it hits the raw end, it becomes an illumination itself.
Fiber optics were out and used in many applications long before we learned that we could communicate over them. ��
va72longhorn is offline   Reply With Quote
Old 08-16-2021, 04:52 PM   #6
MikeB
MikeB's Avatar
My cable looks like it was pinched, but it still works. Will check it for brightness tonight. Also, its special bulb holder doesn't snug up in the panel as well as I'd like. All my others are new and tight. I may use a dab of silicon sealant.
Mike
Old 08-16-2021, 04:54 PM   #7
Caddylackn
Caddylackn's Avatar
If the end is scratched or hazy you can polish it to increase the light output
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 08-16-2021, 05:45 PM   #8
va72longhorn
Alcohol wipe like you use on your glasses does a good job too.
Old 08-16-2021, 05:56 PM   #9
Thealien
Thealien's Avatar
Try bending the little tabs on the socket a bit. Has worked for me but not always.
