01-12-2021, 09:12 AM | #76 |
Re: C20/cummins 12 valve
And it begins. Need to get replacement panels. Like the electric 6 inch sander. Not to crazy about the burnishing polishing machine |
01-13-2021, 09:49 AM | #77 |
6>8 Plugless........
Getting it blasted might not be a bad idea. Make sure all your mechanical stuff get sealed up really well. Nice on new house and shop. Nothing wrong with that.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-13-2021, 11:36 AM | #78 |
I was thinking about getting it blasted. Not that many guys that do it in my area.
06-22-2021, 11:09 AM | #79 |
Need to get a few body panels.
Anyone used Raybuck or c2cfabrication? Posted via Mobile Device |
06-29-2021, 08:40 PM | #80 |
Re: C10 suburban /cummins 12 valve
06-29-2021, 08:41 PM | #81 |
Updates
07-01-2021, 05:51 PM | #82 |
Score on mirrors?
07-08-2021, 03:59 PM | #83 |
Better do it right.
08-05-2021, 11:10 PM | #84 |
Update
08-14-2021, 08:24 AM | #85 |
I think at this point I should move this to suburban builds. How do I go about that?
08-15-2021, 11:08 PM | #86 |
Update
08-15-2021, 11:10 PM | #87 |
Re: C10/Suburban Cummins
Had me confused for a while. Don't do the same mistake I did. You need to trim this back end.
08-16-2021, 07:48 PM | #88 |
Looking good!
08-21-2021, 11:15 AM | #89 |
Re: C10 Suburban Cummins
This is what I was talking about.
Don’t remove! |
08-21-2021, 03:56 PM | #90 |
Went with POR-15 for all the inside.
08-21-2021, 08:06 PM | #91 |
Looking good! Also looking familiar, I did similar work on my 70 K10
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
08-22-2021, 01:55 PM | #92 |
Little spot welds
08-23-2021, 12:56 PM | #93 |
At least your inner wheel house wasn't all rotted out. As far as moving the thread, I'd almost leave this one here and then start a thread in the suburban area showing the progress on the burb. Thats what I'm doing on my wife's 72 burb.
08-28-2021, 09:55 PM | #94 |
For your 1st timers like me:
1. Try to get all your panels from same supplier. Bottom lip where you tac to the wheel arch had to be modified to look somewhat the same. 2. Make sure you have some support on the inside pushing the panel out. I was so worried about not having big gap that I didn’t notice that the top weld from the door to the wheel arch had pushed in. This is because this section of the panel only has a horizontal support. The back half has a vertical support so didn’t have an issue on the back 1/2. 3. This was not an issue but when you weld jump around on the welds to avoid warping. Hopefully these pics will help the next guy trying to do this job. |
08-28-2021, 10:03 PM | #95 |
1. This back had no issues.
2. This is the inside support. 3. Inside support. 4. This is where I see an issue. Since no inside support. Make sure you have something pushing the panel out before you weld. 5. Since I used 2 different suppliers for my panels. They required some modification to make them work. Stick to one supplier if possible. |
09-06-2021, 12:27 PM | #96 |
Looks like the rear light panel is a little off.
08-03-2023, 09:08 AM | #97 |
Getting back into it.
08-03-2023, 09:29 AM | #98 |
The Older Generation
Good deal! Glad to see you back on it. I'm having the same problem with my project, too many interruptions.... LockDoc
08-03-2023, 10:16 AM | #99 |
That's looking good. I need more time to dwindle the project list down so I could work on the wife's burb.
08-06-2023, 03:15 PM | #100 |
Not bad.
