Old 07-16-2004, 12:15 PM   #1
miket
miket's Avatar
Thumbs up Adding a CS144 140 amp to your truck
After doing this recently on my 71, I put together a small outline...
http://classicgmtrucks.proboards33.c...998112&start=0
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 07-16-2004, 01:25 PM   #2
smokekiki
Mike
smokekiki's Avatar
Thanks Mike,I saved it to a folder for future use.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 07-16-2004, 02:29 PM   #3
19CHEVY68CST
Nice clean job and I too will keep this on file.
19CHEVY68CST is offline   Reply With Quote
Old 07-16-2004, 06:18 PM   #4
krue
Designated A-hole!
krue's Avatar
It's on my hard drive. You might want to copy it to a thread in the FAQ section!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-16-2004, 11:13 PM   #5
miket
miket's Avatar
Pics and schematic added.
Old 07-17-2004, 08:24 AM   #6
Yukon Jack
Yukon Jack's Avatar
Nice writeup - I'm sure I have said this before but your engine is awesome looking! I'm using a 454 out of a 89 1 ton with it's alterntor - wonder how I could find out what it's amp rating is, I'm assuming it would be at least 100 amp.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-17-2004, 10:14 AM   #7
Mike C
Mike C's Avatar
Mark, most likely your alternator is a 12SI 105 amp.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-17-2004, 11:32 AM   #8
miket
miket's Avatar
I would agree.
And thanks for the compliment.
Old 07-18-2004, 01:40 AM   #9
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Hey Mike,thanks for the credit at the bottom of your write up.Nice job.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 07-18-2004, 11:12 AM   #10
miket
miket's Avatar
Anytime....thanks for your help.
Old 07-30-2004, 07:09 PM   #11
miket
miket's Avatar
Thumbs up
well guys--I am starting phase II and found a cool fuse/relay/distribution box to tie everything together....http://classicgmtrucks.proboards33.c...998112&start=0
Old 08-01-2004, 06:09 AM   #12
kbs71
71 rustless in texas
kbs71's Avatar
You guys should check out www.madelectrical.com, I bought his CS12 rewire kit along with several other items. Mike spent about 45 mins. just B/Sing with me about my ideas when I ordered the stuff from him. He even threw in a couple of items for free.
Took me about 2 hrs to manufacture the harnesses and about 5 hrs to rewire the alternator and charging system. I also installed 40 amp headlight relays all where the external voltage regulator used to be. It's a sweeeeeet looking install, and works great....
kbs71 is offline   Reply With Quote
