08-18-2021, 04:14 PM | #101 |
Re: Facebook Finds
1983 GMC 1500 sierra C10
Short bed Fuel injected V8 350 Turbo 400 Lowered Aftermarket seat Billet Specialties wheels Runs and drives good Currently registered Asking $9900 https://www.facebook.com/marketplace...8-b0f12fd132b2 |
08-18-2021, 04:16 PM | #102 |
Re: Facebook Finds
1979 Chevrolet C20
179k total miles Gas 2wd Two tone white/Blue Blue interior Up for sale is my 1979 C20 Scottsdale project truck. I am moving out of state so sadly it has to go. It runs and drives and the motor and transmission are solid. Both were rebuilt at 150k miles. There is a electrical issue with the truck that drains the battery slowly, should be an easy fix but I haven't had the time to do it. Registration is current but it will need a new smog pump to pass emissions. I have an old pump that can be rebuilt and all the emissions hoses are included, but not installed. This is a solid project truck that is very close to being a reliable daily driver and im sad to see it go. Asking 4000 obo https://www.facebook.com/marketplace...8-b0f12fd132b2 |
08-18-2021, 04:18 PM | #103 |
Re: Facebook Finds
$1500 Clean title, an older gentleman owned this truck and took very good care of into. It needs a starter, my dogs chewed the backlights wires, and I owe $2,000 in registration fees. It’s been parked for 4 years but prior to this it was running great, motor and transmission are strong. I just have financial difficulties so I have to sell. 101,000 original miles 454 long block 7.4 L Manual transmission, 3 speed
08-18-2021, 04:20 PM | #104 |
Re: Facebook Finds
27000 original miles
2nd owner after the government Not currently running, bad injection pump. Can make repair for added $1000 Dana 60 front with limited slip 14 bolt full floater with detroit goc locker Th400 NP208 Still 24V Military passed it along to the department of Agriculture, still has agg sticker on it. No rust Can assist with shipping https://www.facebook.com/marketplace...8-b0f12fd132b2 |
08-18-2021, 04:22 PM | #105 |
Re: Facebook Finds
08-18-2021, 04:23 PM | #106 |
Re: Facebook Finds
977 GMC C35 1 Ton · Truck · Driven 9,999 miles
1977 GMC C35 1 ton dually, camper special, 3+3, 454 TH400, 2WD, many new parts, AC complete and 134A, needs electrical work, good tires, recent brakes, hydroboost. Comes with spare single cab for donor sheet metal and other body parts. $6000 obo, make offer https://www.facebook.com/marketplace...8-b0f12fd132b2 |
08-18-2021, 04:24 PM | #107 |
Re: Facebook Finds
08-18-2021, 04:25 PM | #108 |
Re: Facebook Finds
08-18-2021, 04:29 PM | #109 |
Re: Facebook Finds
Price is $11,000
Price is $11,000 Facebook won't let me put that. 1974 Chevy c30 crew cab dually with a cummins swap. Cummins 12v Engine and 5 speed manual transmission were removed from a 1992 d250 with 146k miles. Dana 80 rear end. Runs great. Has some rust in the door corners and floor of the bed. Has a power steering leak and the column is sloppy. Great werk truck or just something to enjoy. |
08-18-2021, 04:34 PM | #110 |
Re: Facebook Finds
Read Entire post -if it’s listed it’s for sale .
1978 Chevrolet C-10 Cheyenne Short Box (SWB) . Fresh 350 V8 crate motor, Edelbrock aluminum intake, carburetor, MSD ignition with 700R4 automatic transmission , Factory tach, tilt column, power locks and A\C. Runs and drives, the body is straight and is a great start towards a restoration . The A/C is there but needs attention. The transmission shifts fine but surges in high gear at higher speeds . The Speedo needs a new cable most likely and the dash lights need work . The truck is not perfect and will need little things repaired or replaced . Clean Colorado Title . Vehicle located in St George Utah . Cash purchase or would consider trading for 68-70 Torino fastback, 66-67 Fairlane 2dr Hdtp or Mercury Comet 2dr Hdtp 64-65 Falcon/Comet https://www.facebook.com/marketplace...8-b0f12fd132b2 |
08-18-2021, 04:35 PM | #111 |
Re: Facebook Finds
08-18-2021, 04:41 PM | #112 |
Re: Facebook Finds
Gmc k10 standard cab short bed 4x4 6.2 diesel pickup 147xxx miles. Runs and drives good, factory a/c needs a charge. Body is all original, one small dent beneath passenger door. Runs and drives good, its been my daily driver for the past year. Not a perfect truck, but not very far from being a perfect truck either. Rust free, bondo free. https://www.facebook.com/marketplace...f-3353d184cc6f
08-18-2021, 04:42 PM | #113 |
Re: Facebook Finds
08-18-2021, 04:44 PM | #114 |
Re: Facebook Finds
08-18-2021, 04:47 PM | #115 |
Re: Facebook Finds
1977 GMC C35 1 ton dually, camper special, 3+3, 454 TH400, 2WD, many new parts, AC complete and 134A, needs electrical work, good tires, recent brakes, hydroboost. Comes with spare single cab for donor sheet metal and other body parts. $6000 obo, make offer. https://www.facebook.com/marketplace...f-3353d184cc6f |
08-18-2021, 04:59 PM | #116 |
Re: Facebook Finds
08-18-2021, 06:50 PM | #117 |
Re: Facebook Finds
1978 Chevrolet Cheyenne Fleet Side Short Bed Pick Up
One owner San Diego, California bought and owned square body Chevy PU. Back from the tune-up shop on August 4, 2021 (runs great!). Passed smog on August 5, 2021. Perfect candidate for restoration project. 25k miles on engine overhaul. 350, ci bored 30 over, mild RV cam, balanced and blueprinted. Rebuilt T350 trans, posi-traction rear differential. Replaced seat upholstery and headliner. Radiator was rebuilt with 4 cores. All work professionally done. Good tires, extra right/left saddle tanks, comes with 2 extra clean/straight doors. Factory A/C converted. Has the aluminum frame aftermarket sliding rear window. Original rear fixed window comes with. Heater fan and heater core recently replaced. I have the original interior door panel seen missing from the passenger door in one of the interior photos. Comes with original rims (additional 5 rims) but they need to be bead blasted and painted/powder coated. 5 Dick Cepek 8 spoke 10” wide rims included. Books included: GM 1978 Chevrolet Wiring Diagrams Chilton’s Chevrolet GMC Pickups 1970-80 How to Rebuild Your Small Block Chevy How to Hotrod Small-Block Chevy How to Tune Your Car Miscellaneous extra parts thrown in (new fuel pump, snow chains, etc). La Mesa, CA Location is approximate https://www.facebook.com/marketplace...0-16463da1d28e |
08-18-2021, 06:55 PM | #118 |
Re: Facebook Finds
08-18-2021, 07:06 PM | #119 |
Re: Facebook Finds
08-18-2021, 07:13 PM | #120 |
Re: Facebook Finds
Selling a 1975 C-10 pickup with 45k original miles on it! Yes it really only has 45k miles on it! I originally bought this truck for parts for my truck but I decided that its too nice to just part it out. It has virtually zero rust in it besides the passenger side of the bed on top of the wheel well and it is super straight otherwise. It has the original engine in it but it doesn’t run and I don’t know anything about it, I bought it this way. It also has a 4 speed manual transmission. The paint will shine right up with some cool patina if thats the route you want to go. Bring a trailer! https://www.facebook.com/marketplace...f-c8a961f89abe
08-18-2021, 07:17 PM | #121 |
Re: Facebook Finds
$6,000. I have a 1986 c10 99% rust free, body is really straight besides a small dent on passenger side fender.
Engine: 305 Trans: auto Dual fuel tanks and both work New parts New trans filter, resealed trans pan, Trans flush Brand new wheels and tires 4in drop all around New spindles up front New drilled and slotted rotors New pads New radiator New upper and lower radiator hoses New t stat New battery New edelbrock avs2 650 New exhaust A/c works!!! Cons -Dash has some cracking -Carpet is ripped where the feet are -Has all power options but Needs new window motors Just little things here and there! Not in any hurry to sell at all I have to have the right offer or trade, looking for other classics just let me know what you have I will post more photos when I get a chance I’m sure I’m forgetting things! https://www.facebook.com/marketplace...f-c8a961f89abe |
08-18-2021, 07:20 PM | #122 |
Re: Facebook Finds
08-18-2021, 07:22 PM | #123 |
Re: Facebook Finds
08-18-2021, 10:41 PM | #124 |
Re: Facebook Finds
79 chevy long bed, 2wd, 350ci, 4 speed manual. Runs and drives great. $4500 /OBO/trade? No junk please. Call Mike https://www.facebook.com/marketplace...3A108%7D%22%7D
08-18-2021, 10:46 PM | #125 |
Re: Facebook Finds
This is a 1985 pickup C10 that I was going to cut down to make a short box out of. As you can see in the photo I have a short box already with two replacement sides from a Suburban for the short box. I also have a short bed Stepside most of it in the bed of the truck right now. So what you are getting.
1. 1985 Chevy long bed that pretty straight 1 . One short bed Fleetside box comes with patch panels 1 mostly complete- tailgate short bed Stepside box Truck runs and drives has a 4.3 V6. https://www.facebook.com/marketplace...8-0cf0f9684f13 |
