Old 07-18-2004, 10:39 AM   #1
BowLowTie
Man, I broke off an "EZ-Out" inside ...
a brass brake fitting going into the proportioning valve. Am I scre#$d now? The brass nipple broke flush with the steel, then the EZ-OUT puller broke, too.
HELP!!!
BowLowTie is offline   Reply With Quote
Old 07-18-2004, 10:48 AM   #2
grayw0lf
It shouldn't be too hard to find a new prop valve on here. You can probably get tone pretty cheap. I wasn't planning on selling it, but if you need one for a drum/drum setup, I have a good one in the garage attic.
You can either use a double flare tool & put a new fitting on it. Or, you can buy a short piece w/ the flare already on it & use a joining compression fitting on the other side.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 07-18-2004, 03:39 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
what ever you do, DO NOT USE COMPRESSION FITTINGS!!! they are not designed for the high pressures in a brake system. (upwards of 3000 psi) they may hold under normal use but will fail in a panic stop. they leak where ring meets tube. use inverted flare fittings only. I dont want people to get hurt.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-18-2004, 10:17 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Best way to get the easy out out is with and end mill, using a flat bottomed cutter. If you have a buddy with an end mill, good. If not, best to buy a new valve.
New valves aren't cheap, a repop with bracket & tubes is about $90. Adjustables are around $50.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-19-2004, 01:03 AM   #5
Ogier
Chopper/Painter
Ogier's Avatar
If you have access to a mig welder and a nut, weld the nut to the end of the easyout wait for it to cool and remove it. Don't continue to try and remove the piece you were trying to remove in the first place without getting a new easyout first. They use some heat from a propane/mapp gas torch...
Hope this helps
Ogier
Ogier is offline   Reply With Quote
Old 07-19-2004, 08:13 AM   #6
Southpa
Southpa's Avatar
Another option is to go to your dentist! Yes, I'm not kidding! They carry the best dremel bits you can find. Use a fine bit to cut a slot in whatever is stuck in there, insert screwdriver and unscrew.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 07-19-2004, 08:40 AM   #7
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
That easy-out isn't coming out unless you have some super drill. I managed to break an easy out inside of a grade 3 bolt in the back of a block where the tranny bolts up... and we drilled for 3 days straight (3 days of auto shop @ 4.5hrs each) and the thing didn't budge. Managed to kill 3 bits tho.
1BadSS is offline   Reply With Quote
Old 07-19-2004, 09:11 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Easy Outs are made of very rare steel. They are made from the old worn out hinges of the gate to Hell. Nothing is harder than those things.
I have never, ever seen a drill bit that will even touch one.
You'll be miles ahead to post on the parts board asking for a used prop valve.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-19-2004, 11:06 AM   #9
mnick
Find someone in your area that has an e-lock machine. This machine was designed to remove broken hardened bits and extractors. They can be hard to find but once you watch one you'll wonder way you ever drilled anything out.
mnick is offline   Reply With Quote
