Old 08-23-2021, 11:40 PM   #1
hdixon
Uni Steer Rack N Pinion
Has anyone used a Uni Steer rack n pinion and had problem with the outer tie rod. I have a 69 step side disc brake on all 4 corner I am using a Uni Steer rack n pinion with Cpp 73-87 spindles and I can't fine the correct outer tie rod to fit the 73-87 spindle correctly while using the Uni Steer rack n pinion can anyone shade help me with this issue please if you have these items mounted on your c10 or has had this issue I can not get the frontend align property any help would be great buying a lot of part and still back at square one called Uni Steer they can't help
thanks
hdixon is offline   Reply With Quote
Old 08-24-2021, 07:35 AM   #2
mkmc69
mkmc69's Avatar
Re: Uni Steer Rack N Pinion
I would send it back to Uni Steer and get your money back, in my opinion. I had one of their systems on my 66 Nova a few years back and I did not like it at all. I had a tighter turning radius with the original steering than I did the Uni Steer rack. I asked several questions, got zero answers. Long story short, I regretted buying it. Sounds like nothing has changed with them to me. Again, just my opinion. Hopefully, someone else has had better luck with them than I did.
mkmc69 is offline   Reply With Quote
Old 08-24-2021, 08:15 AM   #3
hdixon
As of right now I am not happy at all I called and spoke with one of there customer service rep explain my problem to them they said they would call back twice now no return call I guess all I can do is write a bad review so other can see what kind of product they are selling once you purchase you are done
Old 08-24-2021, 10:40 AM   #4
mkmc69
mkmc69's Avatar
Man, that sucks. I feel bad for you. The aftermarket stuff is hit and miss. Some of it is great, and some of it is just plain crap. Good ideas, but poorly engineered.
Old 08-24-2021, 03:59 PM   #5
typerr
I would contact Rob at No Limit and see what he has to say. Even though you went with Unisteer and not his kit I'd bet he can point you towards a solution.
typerr is offline   Reply With Quote
Old 08-24-2021, 06:24 PM   #6
Woodnears
the guys that lay frame just drill out the spindle and use a heim joint in place of the tie rod end.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417
Woodnears is offline   Reply With Quote
