Kickdown cable location
Got another question, trying to reinstall the kick-down cable on my 70 cst10.
I know where it attaches on the carb. But I am wondering if I might be missing a bracket for the adjustable part of the cable. Before I had it installed on the coiil bracket,under the coil. Me and my son have a on-going argument I say it goes there, he says it does not. Am I missing a bracket, just because it was always there, don't make it right.. would anyone happen to have a pick or some incite. Thanks, Trey |
Re: Kickdown cable location
It has a dedicated bracket that's separate but sits on top of the plug wire stands. Mounts using back two manifold bolt holes on driver's side. At least it's that way on a 72
#3 | |
Thanks for the pic. |
![]() Join Date: Dec 2014
Visit a junkyard, there are lots of different brackets out there that do the trick, although they may not be the factory correct one.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
![]() Join Date: Aug 2019
If you change the location ( on the intake man ) you may need a longer or shorter kick down cable. Pay attention to what year you get the bracket off of.
