![]() Join Date: Nov 2012
Door panel screws question
I am SO sick of dealing with these door panel screws that are "WELDED" in place with RUST.
I just bought 1/4- 20 cage nuts and when they arrive, I am going to replace the old screws with stainless steel hex bolts and washers. Has anyone else tried this? It seems to me that I would never have to worry about the screws being "welded" in place anymore. Screwdrivers are useless against these screws whenever this happens.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
#2 | |
![]() Join Date: Feb 2002
Re: Door panel screws question
I use #3 phillips flush screws [1/4-20] with a 1/2'' wide head. Works well. Pickup has a home made ''custom'' wood panel. K/5 is padded in vinyl.
I use stainless steel screws with nylon nut insert (like the ones license plates use).
The Older Generation
I did what Roboticjunky did, only I used the original screws with the plastic inserts. I still put a little anti-seize on the ends of the screws though..... LockDoc
![]() Join Date: Dec 2013
How does one get a cage nut attached?
Thanks |
A cage nut houses a standard nut in a cage with a spring. The cage has two wings that can be pinched together to allow the cage nut to be inserted into a square hole. The wings are then released to hold the cage nut in place.
Here's a video. https://www.youtube.com/watch?v=xVUvNzZGlLo |
![]() Join Date: Mar 2003
I've always just wire brushed them after I got them out and put a dab of grease on them going back in
The cage nuts that I ordered came in. I drove to where my truck is being repaired and I knocked out some of the old rusted door panel nuts to replace them. But I made a huge mistake before I realized it. I had a perfectly usable nut still in place on the passenger door on the side that is closest to the hinges. I totally forgot that there is no rear access to be able to put a cage nut on the inside of the door. I had already knocked out the perfectly usable one but it is too late now. Now I must replace it with one of these plastic nuts that can be inserted from the front rather than the rear. What a stupid design! I don't understand why GM did this.
![]() Join Date: Mar 2015
I always use never-seize on new screws.
If you can't get them out just drill the head of the screw off. Then you can get the door panel off. Then I use vice-grips on the back side and unscrew them to the inside of the door. You can heat them if necessary with the panel off. I was always amazed how quickly these will seize if left unprotected with some type of lube. |
