#26 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: sliding windows
Thank you it is the soft ray I'm after - have a clear set in place. Happy to scrape tint if need be.
For info sake I'll set a single pane slider next to a double pane slider and compare to a spare 2x wall pane to check dimensions between the slider types.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
#27 |
Re: sliding windows
This has evolved into a thread with some good info. Many oft-repeated questions definitively answered here.
#28 |
Carpe manana
Re: sliding windows
Update. Looks like more info helps confirm it's the 1x wall top that the single pane slider instructions call for trimming. Odd though as I set a single pane slider next to a double pane slider and the outer dimensions do not appear to differ. Many months from now I plan to install single pane sliders in a 1x wall top without trimming. Will post result when I do.
Meanwhile the following show single pane sliders removed from a 1x wall top in CO (thanks Troy) and the haphazard trim job that was performed. See the wavy inner margins of the window opening. I was shocked at how thin the OEM glass is for a 1x wall top. It's like a tortilla chip.
#29 |
Carpe manana
Re: sliding windows
More
#30 |
Carpe manana
Re: sliding windows
The sliders:
#31 |
Re: sliding windows
Would the sliding side windows of a 1973-91 Blaze(r) fit on a double wall top...1971 Blazer.
#32 |
Carpe manana
Re: sliding windows
No
#33 |
Re: sliding windows
Looking for the website to Steele and a part number for the gasket for the double wall to Single wall top application on the sliders windows
#34 |
![]() Join Date: Apr 2006
Re: sliding windows
Any updates on this?
Kirk 72 Blazer CST 4wd highlander |
#35 |
Re: sliding windows
To the top
| Bookmarks |
