Old 09-05-2021, 08:57 PM   #1
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Let the BBs breath.
Found a Vet dual snorkel air cleaner. Looks good on the 454 and should let it breath. The original air cleaner was fresh air fed from the front core support but would not clear the cowl hood's extra bracing and the high rise intake.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 09-05-2021, 09:25 PM   #2
sweetk30
sweetk30's Avatar
Re: Let the BBs breath.
do you plan to give it back the colder air from up front or just let it suck in more engine bay hot air ?
always loved the look of a twin snorkel filter unit .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-05-2021, 11:53 PM   #3
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I considered it but too much hassle. Different size hoses, no place to add the LH hoses and too much interference with all the junk under the hood.
NOTE: That is a Gen VI late model roller motor, "simplified". QJET carb, (no FI), V-belts (no serp belts) and no computer. I think we could call that "Old School". I got to keep it simple!
Phone: 360-956-7170
Old 09-12-2021, 08:53 PM   #4
Impact02
Impact02's Avatar
What intake did you use. I put a 96 mercury marine vortec 454 in my 72 but it has the iron four barrel manifold and I would like to change it.
Impact02 is offline   Reply With Quote
Old 09-15-2021, 09:54 AM   #5
THI
THI's Avatar
The Vortec 454 is a Large Oval Port head, any Large Oval Port intake will work. Keep in mind the Edelbrock Performer 2-0 is a Peanut Port intake, their Performer RPM Oval Port intakes are Large Oval Port. Weiand make both a Peanut Port and Large Oval Port Intakes for the idle -5500 RPM range.
THI is offline   Reply With Quote
Old 09-15-2021, 09:15 PM   #6
Gregski
Gregski's Avatar
I must say that looks pretty darn good
Gregski is offline   Reply With Quote
Old 09-15-2021, 11:32 PM   #7
Pontiac1976
Pontiac1976's Avatar
looks pretty good.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
