Old 09-06-2021, 09:56 PM   #1
cwcarpenter98
cwcarpenter98's Avatar
Re: Sheared off lower coil mount bolt
Get a strong punch, your favorite, large hammer, and go to town on it. Since the bolt is already shared off, you'll need new hardware anyways. Once you knock the bolt out, then it will be easier to try to remove the spring holder from the bolt. Bolt in a vice and use a wrench on the square nut to work it back and forth until it unthreads. If you can, save the original spring retainers
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
