Old 09-06-2021, 08:59 PM   #1
tinman_local2
K20 front brake hoses 4" lift
I'm needing some new brake hoses for my 69 k20. It's got a 4" lift and a dana 44 from a '79. I can't seem to find anything with the right ends and length. What has everyone else done for hoses? I checked Inline tube's website and I don't think the ones they list are long enough. Any thoughts?
tinman_local2 is offline   Reply With Quote
Old 09-06-2021, 09:08 PM   #2
Louisvillekytruck
Re: K20 front brake hoses 4" lift
Do u have any pics of your truck
Louisvillekytruck is offline   Reply With Quote
Old 09-06-2021, 09:21 PM   #3
kwmech
Offroad Design has longer hoses in braided.
https://www.offroaddesign.com/71-91-...line-kits.html
Old 09-06-2021, 10:15 PM   #4
BASE
BASE's Avatar
I’m pretty sure I got mine from inline tube. It was a set for squarebodies with the rear center and the fronts advertised for 2-4” lift. Fit the 76 D44 I have in my ‘68. I do remember looking for awhile before I found them. I won’t be home for a couple days but I’ll see if I can find something with a p/n when I get back.
BASE is offline   Reply With Quote
Old 09-06-2021, 10:58 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
I used 88-98 C30 front hoses on my ‘57. (88 K5 frame with 4” lift) they were plenty long enough. I’ve got a set of the braided hoses from ORD on my ‘98 with 6” and they are real good quality. I’m going to run a set of those ORD hoses on my ‘72 when I get around to putting the lift under it.
Tyler
Old 09-07-2021, 05:52 AM   #6
I always ask for '78 C20 brake hoses at Napa. Trucks in those years had longer hoses with the right ends. I didn't know the 88-98s will also work. Good to know
Old 09-07-2021, 07:54 AM   #7
tinman_local2
Those look like they would work. They are an inch longer than what Inline tube offers. Just depends on where they measure from. No one states how they are measured. I assume it's an overall length. I'll call them this morning. I have quite the collection of hoses that won't work. Either too short or wrong ends, etc.
Old 09-08-2021, 07:51 AM   #8
tinman_local2
Little update on finding brake hoses. I called Inline tube yesterday. Guess I called them twice, first and last time. Not helpful at all. I asked about custom hoses since they "don't have any stock items" for my application, the guy was super rude and seemed like he really didn't want to mess with my order. Kept telling me he needed to know what ends I needed. Each time I tried to explain that, he says they don't have that. I finally told him I'd search elsewhere and I think that made his day. Anyway, I called ORD. They were friendly, had the hoses and adapters in stock and were knowledgeable about what thread size each end should be, etc. I ordered them right then and deleted Inline tube's number from my phone. I've went almost 50 years without spending a dime with them and plan to go another 50.
Old 09-08-2021, 09:45 AM   #9
MJN
MJN's Avatar
On my '74 K20 I'm running the Pro Comp stainless braided hoses
https://www.summitracing.com/parts/e...ckup/year/1974
I've got them in the stock frame locations and haven't had any issues with them.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 09-08-2021, 10:18 AM   #10
Louisvillekytruck
Can I see a pic of your 74
Old 09-08-2021, 10:38 AM   #11
MJN
MJN's Avatar
Here's my truck and the front brake hoses.. Looks like I need to get some things touched up in spring after looking at these pictures. Also, the OP said his axle is a Dana 44 from a '79 truck but in '79 trucks had a GM 10 bolt front axle.
'17 GMC Yukon XL
VCCA member #58596
Old 09-08-2021, 10:55 AM   #12
Louisvillekytruck
Do u have any side pics of your truck
Old 09-08-2021, 12:28 PM   #13
57taskforce
All about them K’s
Gm still used the 44’s in limited capacity until 80.
Tyler
Old 09-08-2021, 02:07 PM   #14
tinman_local2
It's definitely a dana 44. It's from a late '78 or early '79. The calipers are 10mm banjo. Those started in '79, but the donor truck was a '78. Either way I've got the correct brake hoses ordered 🤞
Old 09-08-2021, 09:01 PM   #15
BASE
BASE's Avatar
Looks like I’m a bit late but finally made it home and checked. Inline pn D-6-9. 73-78 with 2-4” lift. They work on the older SAE calipers. Looked fine when I hooked them up but didn’t drive it before tearing everything apart.
I kinda like the braided hoses with the plastic covering. Just easier to clean/keep clean.
Old 09-09-2021, 08:49 PM   #16
jamie72
jamie72's Avatar
go in napa and ask for front brake lines for a 1975 c20 chevy truck...
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 09-10-2021, 07:28 AM   #17
tinman_local2
I tried that. Wrong size ends. Original truck has 1/4" flare, those lines would be 3/16". Not sure they were quite long enough, either. I've got some ordered from ORD that I'm hoping will work.
Old 09-10-2021, 09:22 AM   #18
52napco
ORD is awesome to deal with..Inline tube customer service sucks bad..Their park brake cables are too short for the K20's and they could care less
52napco is offline   Reply With Quote
Old 09-10-2021, 12:37 PM   #19
tinman_local2
I was very pleased with ORD. Their guy on the phone actually knew his stuff. Inline tube really didn't care if I got something from them or not. I won't try to use them again for anything.
Old 09-10-2021, 03:00 PM   #20
BASE
BASE's Avatar
I had heard enough about Inline Tube that I opted to order the stupid things off of amazon just in case they had to go back.
ORD is great to deal with. Only problem I've had with them is it takes forever to get my stuff shipped.
Old 09-10-2021, 03:43 PM   #21
gmc684x4
I got a set from skyjacker they fit well and can be ordered in diff lengths for lifted trucks
Inline tube issue i find with many vendors as front end people no longer have any training or qualifications like they used to be people with a partsman trade training now its someone off the street clicking buttons
gmc684x4 is offline   Reply With Quote
Old 09-11-2021, 11:01 AM   #22
I dealt with the owner of Inline when I ordered custom length hoses and cables. I felt like I was the first one to get them to do custom. This was many years ago. He said they only do OEM spec. I asked why he couldn't build the same part but to my specified length. Then it was "not responsible if they don't fit". I agreed, they made them, and they worked.
I went to Inline because the rear hose provided in the braided stainless set from Skyjacker (through 4WPW) was all wrong. Wrong size and wrong gender at the axle end. That truck had 6" springs. I never changed my rear hose for a 4" lift, but I use mid to late '70s C20 hoses up front and they work on 71/72 K/20s. There's an unneeded mount tab along the hose I remove.
Old 09-11-2021, 11:15 AM   #23
jamie72
jamie72's Avatar
I have them on my 72 blazer and 71 k20 no issues..
jamie72
member #807
www.antlertalk.com
Old 09-11-2021, 05:09 PM   #24
tinman_local2
Are you using 71/72 calipers? That is where part of my trouble is, I'm using calipers from a '79. That's what the front differential is. I think the ones from ORD will be the ticket. The longest ones Napa had are close to 24". I felt like that is a little short. My lift may be a little more than 4". We'll know more on Monday when they show up.
Old 09-12-2021, 06:13 AM   #25
Your axle being a '79 is why the C20 brake hoses we recommended had wrong ends. I'm glad you got what you needed in braided stainless. I've used those for trucks that were more a performance build. But the C20 hoses suggested do work and are long enough on 71/72s with 4" lift. That is what I show in the picture
