Old 09-13-2021, 09:53 PM   #1
Lancialonnie
Active Member
Re: Building rear differential
OUCH! I hope you are feeling better grousehunter! I just ordered the parts to rebuild my axle. I wanted to run the Yukon dura-grip and 3.73 gears. I received the YDGGM12T-3-30-1 carrier and a Richmond 3.73 gear set 12BT373T. After reading this article I called the vendor asking if they shipped the wrong carrier and they explained that the gear set ending in T meant it would fit in this carrier even though the description states the carrier is for 3.42 and lower. Checking the description for the 12BT373T shows it fits this carrier. Sure makes this confusing!
Lancialonnie is offline   Reply With Quote
