09-14-2021, 09:06 AM | #2401 |
Re: What did you do to your truck today.The 3rd chapter
More like what did I do to my truck for the last month. Evenings after work are getting shorter and shorter!
Converted to long water pump so I could use 5-rib belt pulleys. Added power steering as well. I had to beat the hell out of the frame since it's a '67 and I didn't want to use spacers. Converted to a 12si alternator and rewired to eliminate the regulator and extend to the passenger side. This site is invaluable when it comes to guides on conversions, I tell ya. (Thanks VetteVet) Test drive today!! |
09-14-2021, 09:23 AM | #2402 |
I am sure you will enjoy the power steering. What box did you use and where did you get it? Also, consider getting that rubber hose out of the wheel well.
09-14-2021, 10:10 AM | #2403 |
I used a Lares reman for an 87 R10, 3-1/2 turns lock to lock. If I could do it again I'd get a mid- 70's 3-1/2 turn box because the fittings would match up to 67-72 pressure and return lines. That's also why the return is routed that way, I need a hard 90 bend but it seems the squarebodies are routed different for the return lines. It won't be there for long.
09-14-2021, 07:16 PM | #2404 |
Loaded the stepside on the trailer and took it to powerwash the engine . Came out ok , I put it away this eve and realised I didnt take any pictures. Oh well on a side note the guy that towed my Chevelle last night is interested in it as is . Hes been looking for a stepper for a while wants to put a 12 valve Cummins in it.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
09-14-2021, 08:25 PM | #2405 |
Put an old battery in the truck and turned the motor over for the first time in three years. Had to pull the plugs to get it to turn over as it was a bit stiff from sitting for so long. Also, I taped the hole pattern paper to the firewall for the A/C. Now I just need to build up the nerve to drill it.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
09-16-2021, 09:11 AM | #2406 |
So I took the truck out Tuesday and yesterday, and man is the power steering a treat to park with. I also had a huge amount of slop in the old manual steering box, so cruising down the highway at 55 is actually fun now that there's much less play. The tighter ratio is great too.
I think my reman p/s box is leaking at the input shaft (shocker right). Of course this could be due to poor rebuild quality, but is it possible that my steering column is putting some pressure on the input shaft causing it to leak? When I installed the box, the column was 3/8" off center. I kinda just pushed it over onto the rag joint, so there's probably a little sideways tension on the rag joint/ input shaft. Can I loosen/ adjust the column somewhere so it takes tension off, like at the firewall? |
09-16-2021, 10:52 AM | #2407 |
It was yesterday, but, I installed Hood Pop Springs to my '69. Original to late '90s Cadillac and probably other GM makes around that time. I looked for weeks and finally found this. less than 10 minute install for both. Pops hood a half inch, or so.
09-16-2021, 04:38 PM | #2408 |
Set the new steel bed floor on the frame. Mocked up the fuel fill.
09-17-2021, 06:38 AM | #2409 |
Great work guys, I like the 'popper'' KW
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
09-17-2021, 07:48 AM | #2410 |
09-17-2021, 08:08 AM | #2411 |
I also just brought my C/10 back from the exhaust shop. It was an expensive trip as the tires on my trailer were leaking, seems like I had just put new ones on, but found out it was 16 years ago. Four new tires and rims along with the price of the exhaust, but trailer should last quite a while and truck sounds nice, the guy did an excellent job. All's well for now.
09-17-2021, 10:07 AM | #2412 |
Changed out the drive shaft center bearing. Wasn’t as hard as I thought, cept for a stubborn spline/yoke
09-18-2021, 12:35 AM | #2413 |
Despite not being mechanically blessed (challenged is a better description), I managed to get the HEI distributor replaced. Also did the spark plugs and wires. Is it normal that a set of wires has one that isn't the right length? Auto Zone traded for a longer one, but it's not an exact match.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
09-18-2021, 07:22 AM | #2414 |
Had a new roof installed over it (and we are enjoying the new roof, too) = first rain in many many days!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-18-2021, 07:58 AM | #2415 |
Found the booster brackets locally. Stripped and painted them. Installed a reman brake booster. Nice to have working Power steering and power disc brakes again.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
09-18-2021, 12:02 PM | #2416 |
Mr. Cheyenne
Got these bumper guard protectors from 72ironmike installed this morning. Didn't have them when I installed the bumpers or even new they were a thing, until I saw 72ironmike had a set for sell in the parts section.
Once again 67-72 forums showing me I need something I didn't know I needed LOL!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
09-20-2021, 08:14 AM | #2417 |
Got up early to get some good pictures and shoot a video.
09-20-2021, 08:32 AM | #2418 |
Mr. Cheyenne
That's a nice looking truck, love that blue!
Speaking of blue, where did you come by your Blue Bowtie rally caps?
09-20-2021, 11:32 AM | #2419 |
09-20-2021, 11:46 AM | #2420 |
Doors and fenders painted.
09-20-2021, 12:57 PM | #2421 |
Found the source of the gas smell in my cab. When I replaced the tank I also replaced all of the EEC hoses and reused the original clamps. Those clamps caused the hose to bunch up under the gap in the clamp and allowed a tiny amount of fuel to leak during left-hand turns and a fuller tank. Maybe I had them too tight but I replaced them with worm-style and no more leak or smell.
09-20-2021, 01:04 PM | #2422 |
Over the past couple of weeks I have been working on completely updating the front end with an '80 crossmember adding power brakes & power steering and replacing all of the gaskets on the engine. Before I started I had to replace the radiator and noticed that the new radiator was quite pronounced behind the grill so I thought it might look good to paint the radiator while I had it out. Haven't installed it yet, but I think it will look kinda' cool.
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
09-20-2021, 04:18 PM | #2423 |
09-20-2021, 05:43 PM | #2424 |
09-20-2021, 07:44 PM | #2425 |
Wish they had them back when I did my Tran Am variable ratio 3 turn LL. I had to fab brackets and steering link. But it held up to the 40s and now will turn the little 20s.
