Active Member
![]() Join Date: Dec 2009
57 Chevy 6400 2 wheel to 4 wheel drive
I found this nice 57 truck in North Dakota. I decided to make it a 4x4 since I travel from North Dakota and Washington State often. Installed a 454 with a sm465 4 speed, atlas torque splitter overdrive. Has Dana 70HD rear axle and Dana 60 front. My plan was to emulate a Napco. I have always liked Taskforce Napco's It is now at the shop awaiting wiring and brake lines.
Active Member
Re: 57 Chevy 6400 2 wheel to 4 wheel drive
A few more pics
Very cool idea, and I see you found some of those rare 22.5 wheels for tubeless tires. What are your plans for the exhaust manifold on the driver's side?
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Active Member
I was able to use a corvette style big block exhaust manifold for the passenger side and put it on the driver side. It's tight but will work. Otherwise I was looking at Sanderson cast big block hugger headers.
also c-60 med duty big block manifolds are center style dump .
LOVE the direction this build is going . only thing i might have done was 19.5 p-30 bread truck 8lug drw rims and tires . but the truck still looks killer with your tire/wheel combo .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Active Member
I found a nice seat out of an 88-89 Chevy truck to replace the one destroyed by mice and many hard miles. I wasn't a fan of the extra wood butt support either. I also picked up an instrument cluster from Dakota Digital. It will be easier to adjust the speedometer with electronic unit.
#7 | |
Active Member
I wish I had known about the C-60 manifolds. It took me a while to find one that would work. The factory steering box was a hassle. I did have a set of 19.5s that were 10 lug on the rear. I just wanted to keep the rubber height around 37" like It had on it. Believe it or not the front wheels on this truck were 22.5-8's. I put them back on with 9r's. They are about an inch taller. This is the second chevy of this vintage where I have found 22.5's. The other was a 56. Riveted together tubeless wheels. I did some research and found Chevy started offering them in 1956. I put those wheels on my 68 ford N600. Same bolt pattern. Crazy.... Last edited by elpound; 10-20-2017 at 11:22 PM. |
That was a very creative idea on the exhaust manifold! Should be no problem with the steering box with that.
Any pics of the wheel adapter ? Looks good.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
Active Member
I have pics of them them in the production process and an example of them for another application. Got so excited that I forgot to take some for myself. They were made by Motorsport Tech in Sparks NV. They were made from high grade billet aluminum. 130lbs total weight.
Active Member
Another pic.
Really cool build! That's a helluva lot of aluminum. I'd love to build a medium duty truck one day.
Active Member
I will take some more pics as things progress.
Active Member
I found a 1955 2nd 4400 truck with the cool factory grill guard. Pretty nice truck. It has the extra stainless trim on the cab. I am going to swap bumpers and put the guard on my green truck. I'm not to sure how common these are for the larger trucks. I have seen some for pickups on eBay. I'm pretty sure the guards on the larger trucks are wider because of the wider fenders. I tried to buy the grill guard separately but they wanted to sell the truck complete. Oh well, I sure I will make use of it.
#15 |
This project is SO COOL!!! You're doing an excellent job of emulating the NAPCO feel and staying true to the wheel/tire combo and ride height. Looks so tough!
And score on that grille guard / parts 4400 series truck! Any current photos of the truck you could share?? |
#16 |
Active Member
I don't as of yet. The truck finally made it into the shop where they are going to finish the brakes and wiring for me. They are a smaller operation and my buddies 50 Willys Wagon was first in line. I have not seen it in over a year.My buddy has, and says they are working on it. If I wasn't working all the time I could do it, but in the end, I save money letting them do it. I'm hoping in a couple months they'll have it done. It's a pretty straightforward job compared to what he had done.
#17 | |
Really got my mind going on a bigger truck platform for a Napco-style build as I was originally thinking 3/4-1 ton. |
#18 |
Very nice build, love the original style wheels and adapters.
#19 |
That truck could be my sister 😮
Genesis 1:1 - Revelation 22:21 🙏 '72 GMC C1500 Wide Side Sierra Grande '77 Chevy C20 CCLB (went to go get it 4/29/19!!!) '96 Chevy K2500 Ext cab '97 Chevy K1500 Tahoe (I gotta stop lookin' at CraigsList when I'm bored!) '57 Chevy 6400 (coolest piece yet ![]() |
#20 |
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
#21 |
Active Member
#22 |
Great truck! I keep coming back to this thread looking for the next update but it must still be in the shop.
#23 |
Any updates on the truck?
#24 |
All I can say is how'd I miss it? Very cool. I like the who thing top to bottom
#25 |
Active Member
I did call down to the shop that's been working on it a month ago. They are still plugging away on it. They build a lot of race engines for mud bogging. My truck is sort of a fill in for them. I'm hoping they can turn on it faster with winter coming in ND. Big things that needed done were the electrical, the fuel, and the brakes. Its been a long time.
