Old 09-18-2021, 11:02 AM   #1
ellisjay2
Knife valve for block drain plug.....
I heard of this to make easier for coolant drain......but would this type of valve be ok...i put a 1/4 galvanized nipple in the block then the valve onto the nipple.....I'm thinking to stay with my regular plugs since they came out easy and I don't plan on draining block much......picture is backwards sorry...
: Eli540
86 gmc 2500 longbed Carb 5.7, rwd,
400 tranny.
ellisjay2 is offline   Reply With Quote
Old 09-18-2021, 11:11 AM   #2
Nick_R_23
Nick_R_23's Avatar
Re: Knife valve for block drain plug.....
I wouldn’t trust it. Just gravity/engine vibration/potholes alone would jar that handle downward, and you likely wouldn’t know until the engine overheated.
Old 09-18-2021, 11:18 AM   #3
mongocanfly
mongocanfly's Avatar
If your gonna do that, put a pipe plug in the end of the valve
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-18-2021, 08:28 PM   #4
sweetk30
sweetk30's Avatar
why do you need to drain the system so much is my question ?
x2 on vibration can move them if there to loose internally . i know med and big trucks run a screw type valve for heater core and filter flow control .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-20-2021, 01:19 AM   #5
Pontiac1976
Pontiac1976's Avatar
The only thing that come to mind is some one flushing the block out at the race track to cool down faster between rounds let it out faster. But have seen with old brass rad peacock drain, and hex brass plugs. With the one that on there if it all brass ball valve it would be better for leaks and last longer if your using it for race track. If you want it for less mess draining every 3 to 5 yr cleaning out the system the old brass rad peacock drain may be or would be best for you. If your not going to be using it drain that much do not care about mess then the hex brass plugs would be the best.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-20-2021, 09:01 AM   #6
Corts60
Just here to tinker
Corts60's Avatar
Originally Posted by mongocanfly View Post
if your gonna do that, put a pipe plug in the end if the valve
x2.
Old 09-23-2021, 04:44 PM   #7
THI
THI's Avatar
I use radiator petcock on my blocks for that, very convenient during break-in when using just water. Cuts down on the mess when pulling a block also.
THI is offline   Reply With Quote
