Old 09-20-2021, 01:52 PM   #1
Thealien
Thealien's Avatar
Window sash lubrication
What are you guys using to lubricate where the rollers go in the window sash for the side glass?
I am installing new side glass in one of my blazers soon and I’d prefer to do it once and correct.
Mark
Will it be a problem if the sash is installed about 3/16 to 1/4 inch forward on the glass? My glass guy who is a friend just centered it and an original glass I removed from another door shows it a little more to the rear. I don’t want to make him redo it if it’s not needed. And I also don’t want to install it to find out he needs to redo it?
Old 09-20-2021, 02:03 PM   #2
SIXTY9
Re: Window sash lubrication
I use Dielectric grease. It seems to work well.
SIXTY9 is offline   Reply With Quote
Old 09-20-2021, 03:33 PM   #3
truckster
truckster's Avatar
White lithium grease is what I always used in my glass shop.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-20-2021, 04:22 PM   #4
Grumpy old man
Grumpy old man's Avatar
White lithium grease .
Old 09-20-2021, 04:36 PM   #5
CastIron
CastIron's Avatar
I've replaced a lot of side windows on a lot of different cars and always lubed window regulators with Valvoline synthetic grease. It sticks and doesn't get hard, even in cold temperatures. For the glass run channels, I always clean them really well and wipe on a tiny amount of silicone lube. Doing that will even make an old window work better than a new car.
CastIron is offline   Reply With Quote
Old 09-20-2021, 06:59 PM   #6
Thealien
Thealien's Avatar
Thanks gentlemen. Any thoughts on the sash placement mentioned above.
Old 09-20-2021, 07:26 PM   #7
Grumpy old man
centered , about 3/4" from the edge of the glass .
