Old 09-21-2021, 12:28 PM   #1
Accelo
Accelo's Avatar
Long rear brake line leaks
I purchased an installed the Long rear brake line over 6 months ago. Went to bleed the brakes yesterday and found a leak. It is right in the middle of the line. In the area where I straightened it out from the shipping bend. It isn't stainless steel tubing. I was careful and rolled out the bend on a piece of plywood when I straighten it out. Looks like the hole may be at the seam? the leak is only visible while it is pressurized. I plan on double flaring the existing tubing, while it's installed, and adding a 36 inch section to the end of it. This is a new one on me. Does China make tubing?
Cheers.
Accelo is offline   Reply With Quote
Old 09-21-2021, 12:50 PM   #2
jimijam00
Re: Long rear brake line leaks
Yes, China makes just about everything now.
I've used this stuff, which is allegedly made in the USA.
jimijam00 is offline   Reply With Quote
Old 09-21-2021, 02:19 PM   #3
Caddylackn
Caddylackn's Avatar
I used the same kit to do my rear brake line. I would just redo the whole line, I wouldn't risk splicing in a new piece on that crappy replacement line. That copper nickel is so easy to run and double flare, I would just go all the way from the rear end connection point to the master with new.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 09-21-2021, 05:15 PM   #4
Big Kev-O
Big Kev-O's Avatar
I use AGS for all my brake lines & fittings. Never been disappointed, been using them since I was a kid. Most local auto part store stock the fittings and poly-armor sticks 12-48"long. They sell stainless and copper-nickle coils for a reasonable price. Everything product I bought from them was made in USA.
https://agscompany.com/product-categ...ll-coils-pipe/
Made in America by Americans
Big Kev-O is offline   Reply With Quote
