What do stock master cylinder brake lines look like
I need to bend new 1960 chevy truck master cylinder brake lines for my truck but can't find any pictures of original.
Moderator
![]() ![]() Join Date: Aug 2011
Re: What do stock master cylinder brake lines look like
Not sure if all our years are the same but here is a pic from the Lambrect thread
![]() ![]() Join Date: Apr 2012
He has a 4x4 1960 with the dual brake clutch master
https://67-72chevytrucks.com/vboard/...1966+gmc+panel IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
![]() Join Date: Jul 2012
1962 GMC 4x4
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 |
Welcome
Let me know if you need more angles or better lighting.
#8 | |
I can snap a few pictures tomorrow for you. My 4x4s are GMC with the spicer axles but the only difference should be how they connect to the backing plate. This picture shows a little. I can get a dfew more.
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 Last edited by JPBrecheisen; 09-22-2021 at 11:08 PM. Reason: Adding photo |
#9 | |
Didn't forget your pictures. Got tied up but will get some soon.
Not sure what you mean by snubbers?
#13 | |
I have several trucks like this so I believe this is factory method.
#15 |
#16 |
Those are original to the truck. Bumpers/stops look same front and rear. Only difference is the rears have a block of wood as a spacer. Again, most of the trucks I have are like this so I feel that its factory.
LMC Truck shows they might be available # 30-1828 GM Parts book search shows # 3700034. Did a quick search and it looks correct.
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 Last edited by JPBrecheisen; 09-24-2021 at 11:22 AM. |
#17 |
![]() ![]() ![]() Join Date: Jan 2018
Try searching bump stops. I know you can get them for 2wd, but not sure if the 4wd are different
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#18 |
60 4x4 hydraulic hoses
Looks like I need one for my clutch, does anyone know where I can buy one?
#19 | |
Re: 60 4x4 hydraulic hoses
They're not "factory looking" because they come in braided hose, but they work.
#20 |
#21 |
Don't mind helping. Been own the path on some of it.
If your original is intact you can send for them to copy if for some reason they don't have the application. I had to make minor adjustments to mine when it came. Keep them in mind for parking brake cables also. I've had them make a bunch. Same drill. Send em yours, and they'll copy and send back. Had good luck with them.
#22 |
This is my balance bar but does the main cable attach to a bracket somewhere between the handle and the balance bar?
#23 | |
does anyone know what these 2 brackets are for? Last edited by drumyn61; 09-28-2021 at 12:05 AM. |
#24 | |
Main cable bolts to the t-case cross member with a simple clamp. It runs on the drives side. Will try to get you a photo.
#25 |
Left behind muffler mounts.
The trianglar shaped one with the slot in the end i think is the original. Some trucks had these and ran a metal band arount the muffler body. My `60 apache has one similar although it is 2x4 variety. Hard to tell from the pictures but any mysterious heavy duty brackets could be remnants of a pto driven accessory. By suburban had a few that used to support a pto driveshaft for a pto driven winch. They are commonly on divers side since that is the pto side of the SM420 which i asume is what your truck has.
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 Last edited by JPBrecheisen; 09-27-2021 at 11:40 PM. Reason: Additional information |
| Bookmarks |
