Old 09-24-2021, 01:12 PM   #1
402Bowtie
402Bowtie's Avatar
72 standard vs deluxe door panels
Was having a discussion with a friend...I had in mind that every Cheyenne or Cheyenne Super truck (both have woodgrain door panels) would have from the factory the deluxe-style door panel that has the scroll imprinted across the top (and behind the woodgrain). Is that true?
If there was Cheyenne/Cheyenne Super truck that had standard (no scroll) 72 door panels with trim retainer holes, is that probably a non-factory modification?
Pics of door panels attached.
402Bowtie is offline   Reply With Quote
Old 09-24-2021, 10:35 PM   #2
Chevyland
Chevyland's Avatar
Re: 72 standard vs deluxe door panels
Every Cheyenne or Super I know of had deluxe scroll panels
Behind the woodgrain
Chevyland is offline   Reply With Quote
Old 09-25-2021, 12:45 AM   #3
jocko
jocko's Avatar
It's a good question - I think you hit the nail on the head with the common trim retainer holes - so, yes, I would assume that if you found base/Custom trim level panels behind woodgrain that it would be a homemade job. An additional tell-tale sign would likely be some kinda sloppy (or at least "not perfect") trim retainer holes.
Old 09-25-2021, 05:39 AM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Even the Custom Deluxe trucks got the scroll panels so yeah, I doubt a Cheyenne Super would have had the standard panels because I don't think GM ever punched the trim holes in them.
Ryan
1969 Chevy milk truck
Old 09-25-2021, 06:45 AM   #5
The base door panels were only used on Custom (base) trucks. But you can fit the Cheyenne & Cheyenne Super inserts and retainers onto base doors panels. Seems like a better idea GM should have done. I've always felt it's a shame on Cheyennes to cover up the matching (to the seat) western scroll on the door panels with the woodgrain that is found nowhere else in the interior. I remove it on mine. And I have put the woodgrain/stainless on base panels. You can't tell the difference when installed.
Old 09-25-2021, 07:18 AM   #6
Bones72Super
Bones72Super's Avatar
Thanks for the heads up Tim, now that gives me even more options trying to find a decent set of parchment door panels
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline   Reply With Quote
Old 09-25-2021, 08:03 AM   #7
best view
Makes sense to put them on custom
best view is offline   Reply With Quote
Old 09-26-2021, 07:43 AM   #8
Yep, it sure does. The thought hit me one day and sure 'nuff it works
