Old 09-25-2021, 12:37 AM   #1
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Originally Posted by dsraven View Post
Curious what your rocker height is.
I didn't measure the rocker height. Odds are I'll raise the ride height and probably stagger the wheels. The front wheels are right up against the rims, so I'll probably raise the suspension and run a smaller diameter rim with a low profile tire.
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 09-25-2021, 12:46 AM   #2
dsraven
Re: 1958 Saab story
Did t notice with all you have going on. Is yours AWD or 4x4 or just RWD? Mine is AWD 4x4 so tire outside diameter needs to stay the same.q
Old 09-25-2021, 12:57 AM   #3
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
It's been converted to rwd
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-25-2021, 12:24 PM   #4
dsraven
Re: 1958 Saab story
Will you, or did you, flash the computer to eliminate the 4x4 stuff, body module for accy that wont be used like rear side door locks/windows etc? I haven't done any of that yet other than parse out and remove a few circuits. My plan was to get the frame swap done, then start at the back and work forward, finishing to final epoxy primer. Box is done, now the cab work will start if I ever get the summer projects jar emptied.
Nice work you do with great ingenuity. Thinking outside the box instead of looking for a kit or a bolt on. Great documentation on the site too, it makes me wanna clear out my shop of other "gotta do's" and get back on the 57.
Old 09-25-2021, 12:35 PM   #5
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Madkidd owned it before I bought it. He swapped in the lq4 6.0l and has it dialed in perfectly. He also converted it to 2wd. As for the door circuits, like when I did the Jeep body swap, I just used the wires for the door speakers and the side turn signals. I just coiled up the extra wires and zip tied it up out of the way. I'd like to get rid of the air bag system, because it always says "service air bags" on the dash until you clear it with the trip meter button.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-25-2021, 01:57 PM   #6
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Oh and current rocker height is 7 inches all the front of the front door and 8.5 inches in front of the rear wheel.
- Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-25-2021, 07:28 PM   #7
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I cut 11 inches off the front frame rails. I set the front clip on. I had to lower the back of the truck body because it was pitching the nose of the truck too low.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
