Re: AC Blend door "clip"?
Well then just get a solid round alum rod big enough from home depot. Cut off a section use hack it with Dremel Tool and Accessories. Cut and grind in to shape in 2 hour you should be able get it rough out the Chinese alum test fit fine tuning it for fitment. You can spend as much to finish it to your liking. I did not know you did not want Chinese plastic. The shape is not hard to make. The other option is pc 3D printer buy one or try calling 3D printer shop to do some up for you.( but Plastic again)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
