Re: Easy way to remove motor and trans from donor?
What a bummer. Was the truck in a flood? That's a lot of water. I suspect it can be saved but it will need to be a complete tear down and rebuild. Need to check for cracks in the cylinders and heads. I would pull the pan on the trans.
Still a bummer but you can build it back better. Lots of used stuff over on LS1tech.com.
I had something similar happen to me. Bought a "low mileage" (40,000) LS1 engine and 4L60E trans many years ago. Pulled the pan and front cover to just check stuff. Shiny chunks in the pan and a very loose timing chain. Took it to engine shop and it wasn't pretty. More like 240,000 miles. Put in good rods and pistons. New bearings. Small cam. The block and heads were sound. Heads got a slight port job along with a valve job. Its been in my 98 Wrangler for 13 years. It runs great.
