Old 07-14-2004, 06:38 PM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
rebuilding hood hindges
how can i rebuild my hood hindge are there any kits available?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 07-14-2004, 06:56 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have new GM hinges and springs. Here's the parts numbers:
3911705 LH Hinge
3911706 RH Hinge
3890741 Spring (need 2, naturally)
This is a much better way to go. I understand there would be a cost difference, if we could get a "kit" to rebuild them. But, I don't think I've ever seen one.
I simply went to a local dealership and told them what I wanted. They looked up the parts numbers, ordered them, and called me to come pick them up.
The reason I did that, is that Early Classic Enterprises told me that I could still get them from GM, and for less money than they could sell them to me for. So, later I spent about $1300 with ECE when I redid my suspension. Boy, did I save money, or what??
Member Nr. 2770
Old 07-15-2004, 02:31 AM   #3
Terry Peerson
I rebuilt a set last year for my truck. The kit came with new hinge pins and copper bushings. You will need a good sturdy vise, a BFH, a press to put the pins back in, and a band-saw to cut the pins off (they stick out the bottom if you don't). The hardest part was getting the old pins out. I used lots of "Kroil" penetrant and a big BFH with a punch. Of course, mine were rusted in solid. All-in-all, pretty easy. And well worth the effort.
Good luck!
TP
Terry Peerson is offline   Reply With Quote
Old 07-15-2004, 02:35 AM   #4
71chevylongbed
Got Horsepower?
how much were they at the dealership? can the dealerships order body mounts and battery trays
Old 07-15-2004, 05:39 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
Terry: who did you buy the kit from? How much did it run?
Old 07-15-2004, 07:24 AM   #6
Terry Peerson
I got mine from Chevy Duty here in KC. Don't remember how much but around $ 10.00, I think.
TP
Old 07-15-2004, 09:25 AM   #7
Gee_Emm
You can try mushrooming the rivets that are already there, that might fix them good enough. My Dad bought a brand new set from GM had them chromed and within a couple months they were just as good as his old ones.
Gee_Emm is offline   Reply With Quote
Old 07-15-2004, 10:18 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Good luck!
TP
Dude, it sounds like you're talking about door hinges by your description.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-17-2004, 03:13 AM   #9
'68OrangeSunshine
ChevLoRay-- Thanks for the numbers. I went into the Chevy dealers' today with those and walked out with a brand new set of hood hinges and springs for less than $160 [w/tax]. Hinges were $58 and springs were $15. Weirdest thing, the dates on the hinges looked like they built them in 4/04 and 6/04. Is GM back in production with parts for our vintage trucks?
Terry-- I'll check out Chevy Duty if the kit's for hood hinges, not door hinges. Maybe I can rebuild my old set for one of my other rigs.
Old 07-17-2004, 06:50 AM   #10
Tx Firefighter
They never stopped. You can still buy tons of stuff at the dealer. I buy most of my parts there. Rubber products, grilles, battery trays, rocker panels, hinges, body mounts, brackets, pulleys, the list goes on and on....
Old 07-19-2004, 05:19 AM   #11
Terry Peerson
I WAS thinking of door hinges. Sorry.
TP
Old 07-19-2004, 08:28 AM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
68OrangeSunshine: you're welcome, but I feel bad that they charged so much for the parts. Man, I don't remember spending but a few cents over a hundred bucks, about four years ago.
I was stationed at D-M (69-71), and have my old front tag (LZD 671) on the front of my '69. I had a '64 Bonneville convertible. Went to Quebedeux Pontiac and got a dealer license frame...still got it, too.
Member Nr. 2770
Old 07-20-2004, 04:05 AM   #13
'68OrangeSunshine
"Prices slightly higher west of the Rockies." 1971 was the year I moved to Tucson. I was in the Marines, after North Carolina and the WestPac (Iwakuni, Japan) I was stationed at MCAS Yuma. What a garden spot. I used to drive to Tucson on weekends to cool off!
