Old 08-18-2021, 10:08 AM   #1
6600DURAMAX
6600DURAMAX's Avatar
1972 BLAZER Upper Trim ???'s
Looking to install both lower and UPPER trim on my K5 Blazer build
1. don't believe that K5's were factory with the upper trim option however I have seen K5's with both lower and upper.
2. Do you these builds that have upper use SHORTBED or LONBED upper trim?
3. Looking to order but want to order the correct trim - heard that Mar-K makes the highest quality?
thanks guys
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 08-18-2021, 10:14 AM   #2
6600DURAMAX
Re: 1972 BLAZER Upper Trim ???'s
some build pics
Old 08-18-2021, 11:56 AM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
I think shortbed trim will work. Just need to cut it to fit. There should be a piece that finishes the cut end that comes with it.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-18-2021, 04:16 PM   #4
Blazerowner
Blazerowner's Avatar
I would talk to Mark k and see if they have suggestions. From what I have read their trim is better than nos.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 08-20-2021, 03:23 PM   #5
6600DURAMAX
anyone have specific contact for Mark K
Old 08-24-2021, 01:00 PM   #6
lks dcvn
lks dcvn's Avatar
www.mar-k.com/
lks dcvn is online now   Reply With Quote
Old 08-24-2021, 09:24 PM   #7
Blazerowner
I don’t think I’ve ever talked to anyone but I have seen builds with their upper trim over the years. I think it’s a matter of either cutting one of the trim pieces to fit or maybe they offer it ready to go.
Kirk
Old 08-25-2021, 11:31 AM   #8
6600DURAMAX
HAha - I thought Mark K was a person - its the company hahaha
Other question - does the short bed uppper trim that goes on the bed have an end cap? I know the long bed trim does
Old 08-25-2021, 10:57 PM   #9
Rgatewood
I am getting ready to do upper and lower trim on a 71 blazer and from my research you use the upper trim for a longhorn as it has a 6 in piece that goes on the rear so you just cut to length then you that piece to finish it off. I just ordered mine from marK but they are about 6 weeks out. So we will see when it gets here.
Rgatewood is offline   Reply With Quote
Old 08-26-2021, 04:21 PM   #10
Harold Holbrook
I got NOS upper Trim for a long bed, Were the molding comes apart I cut mine down to fit exact .
Harold Holbrook is offline   Reply With Quote
Old 09-30-2021, 06:11 PM   #11
da-burb
"Ochre Ogre"
da-burb's Avatar
I have supplied trim for about a dozen "Cheyenne" version Blazers. We do the upper short bed kits without the cab corner pieces. The upper bed molding has 3 pieces. It has an end finish extension with spline that you can remove, shorten the long piece, and reinstall to make the correct length K5 upper molding.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
