Old 09-27-2021, 12:28 AM   #2451
cab4word67
cab4word67's Avatar
Re: What did you do to your truck today.The 3rd chapter
Whats everyone using for pictures My Imbb.com just quit? and removed all my pic
Got em back site was down??
cab4word67 is offline   Reply With Quote
Old 09-27-2021, 08:07 AM   #2452
67C10Step
67C10Step's Avatar
Slipped everything together this weekend. Still need to install the fender braces before I tighten it all down. Rear lights need wiring and bed ground to frame. Been just under 2-1/2 years from dragging it out of a shed and now. Lots of hours and $$ spent but I think I'll have a solid runner by spring. Lots done and lots left to do.......
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 09-27-2021, 08:20 AM   #2453
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks good
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 09-27-2021, 08:22 AM   #2454
maverickmk
maverickmk's Avatar
I use imgur.com
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 09-27-2021, 08:41 AM   #2455
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
This weekend played with my distributor springs - set them up this time to bring in timing just a tad later and the cerve to be a bit more even. It is actually the default factory configuration. It only takes a bit to pop of/on new springs.
However, this time a little brass washer popped off that goes under one side of the spring. It took me nearly 2 hours to find that darn thing, which ended up bouncing forward of the distributor and rested under the divorced choke on the intake manifold. I really thought I wasn't going to find the darn thing!
Also got a new gas cap from the parts section for 72 gas tanks, fits so much better than the repo and look tons better too. I've ordered new valve grommets and a oil cap. After spending hours looking for that brass washer with my face 3 inches from the engine, I notice oil leaks around the grommets/cover and oil cap.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 09-27-2021, 02:14 PM   #2456
KW5413
KW5413's Avatar
Drove it like I stole it...straight to a local car show. She picked up "Best Of Show- Truck"
KW5413 is offline   Reply With Quote
Old 09-27-2021, 03:35 PM   #2457
Carl Spangler
Carl Spangler's Avatar
I use Smugmug which is a paid professionally run image server. Basic cost is $55/year. If you're into archiving photos/vids it's a super useful platform.
1971 SWB step side: Original NM Forestry truck, then NM Fire truck, and now a ranch truck.
Carl Spangler is offline   Reply With Quote
Old 09-27-2021, 08:00 PM   #2458
cab4word67
cab4word67's Avatar
Love to see more pics. I really like the hood.
Old 09-27-2021, 08:06 PM   #2459
CBrown680
Hood off and ready to install the new intake and carb
CBrown680 is offline   Reply With Quote
Old 09-28-2021, 07:05 AM   #2460
Happy_dan
Happy_dan's Avatar
I use imageevent.com
I think it's about $55 a year for unlimited storage. Great when you have videos to share too because they take a lot of room. I have stuff on there from 2000
Happy_dan is offline   Reply With Quote
Old 09-28-2021, 08:48 AM   #2461
KW5413
KW5413's Avatar
Thanks.
More pics from "Welcome" Thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=825880
Old 09-30-2021, 08:18 PM   #2462
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
This wasn't actually today but I just got the photo today. My truck was used for a photo shoot at the Lady Bird Johnson Wildflower center with their staff - not sure what publiciation / social media thing they are using it for but something to do with UT Austin and LBJWC.
They really loaded up the bed with people! LOL
Richard
Old 09-30-2021, 08:36 PM   #2463
Ben IV
Started switching over to a one piece driveshaft.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 10-01-2021, 09:08 PM   #2464
cab4word67
cab4word67's Avatar
Spent last few days installing a new set of 3.73 gears and all new bearings. seals. Modified my flip kit and gained 1-1/8" of travel before hitting the bump stops on the C notch. Then took out one more leaf spring (#4) from the set witch is giving me a smoother ride. Got some work to do on the underside of the wood floor then the fuel tank goes in and we can roll down the road again.
Old 10-02-2021, 09:11 AM   #2465
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
I been fighting a oil leak since my engine rebuild a year ago, I even asked my shop to look to see if my oil pan needed to be resealed. Like my brother told me, it's a old truck they leak and the leak isn't bad. The shop said all they could tell is it looked like oil was coming from the cap and perhaps the dipstick.
Fast forward to when I was working on my distributor springs, I saw oil coming from my grommet on the breather tube on the passenger side valve cover (goes to the carb / air filter base). So I got new grommets for both the passenger breather tube/PCV Valve, new proper 90 degree PCV Valve, and oil cap.
When I had things all apart I found the Flame arrestor was so gunked up I could hardly blow air through it. Took me forever to get it cleaned out but I did (seems you really don't need to replace them, just keep them clean).
Now after 50+ miles and checking the truck this morning after sitting overnight - there is ZERO oil anywhere on my oil pan, starter, flexplate cover or garage floor! Hallelujah!
Richard
Old 10-02-2021, 02:04 PM   #2466
FL71C10
Nice job, good detective work!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 10-02-2021, 06:49 PM   #2467
KQQL IT
At the body shop.
KQQL IT's Avatar
$15 swap meet air cleaner.
Cut chop hole saw weld
Dual snorkel air cleaner
Old 10-02-2021, 11:31 PM   #2468
BK72BURB_3/4Ton4x4
BK72BURB_3/4Ton4x4's Avatar
Farm Truck - just bought it, making a 'to do' list
My Suburban needed a friend and I needed a good farm truck so now we have a new family member
BK72BURB_3/4Ton4x4 is offline   Reply With Quote
Old 10-03-2021, 07:23 PM   #2469
KQQL IT
At the body shop.
KQQL IT's Avatar
Son welded it all together. Quick spray bomb
Old 10-03-2021, 08:09 PM   #2470
rbbc
Installed a new tailltight wiring harness along with the taillight/back-up light assembles, bulbs, and lenses. Also ordered a bunch of parts. I'm getting ready to pass inspection and get her registered!
rbbc is offline   Reply With Quote
Old 10-03-2021, 08:38 PM   #2471
Davidf
Fixed vibration from rear axle. Turns out pinion/yoke nut was loose so had slop there. Also, u-joint had side to side slope in yoke. So super loosey goosey connection between driveshaft and rear end. Or too noticeable at speeds up to 65 except on decel you could feel a rumble. Over 65 and the rear slider window seems to want to rattle out of the truck due to the harmonic vibration.
So, pulled yoke, replaced seal. Removed rear cover and ring/pinion/spiders seem fine. To fix the slope of the u-joint in the yoke, I could see one location tab was worn thinner than the other. So, I add weld material to the tab and used my Drexel cutoff wheel to re-machine the tab to the correct clearance. Tighten up pinion nut with impact not worrying about the crush sleeve. After reassembly, the entire u-joint/yoke assembly is super tight with not discernible play.
Vibration is gone…happy days.
Davidf is offline   Reply With Quote
Old 10-05-2021, 03:23 PM   #2472
1968 K20
Got the bed painted, still need to spray the bed liner and undercoating.
1968 K20 is offline   Reply With Quote
Old 10-05-2021, 05:21 PM   #2473
3757chevy
3757chevy's Avatar
I LOVE that GREEN.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 10-05-2021, 05:21 PM   #2474
67C10Step
67C10Step's Avatar
^^^^LOVE that green. Sparkles almost hurt your eyes in the sun.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 10-05-2021, 07:40 PM   #2475
cab4word67
cab4word67's Avatar
Yes that is a beautiful color, cant wait to see it all together
